SOURCE: ink problem
Check to make sure nothin is jammed in your printer. I had that happen to me, either my kids or my cat got something small stuck in the printer and it created a blank horizontal line down the page. Hope it's something that simple!!
SOURCE: Brother MFC 425CN will not print black
Have a look at the bk cart. Did you fix it well into position by clipping the support above the cart?
Can you see any difference by ink fuel before and after cleaning cycle? If there is no difference the valve is not open: drill a hole into the top cover and leave it open. Try another cleaning cycle again.
SOURCE: "NO CARTRIDGE" MESSAGE ON BROTHER-425CN
try this:
take all carts out. Unplug machine from power outlet. wait 5 min. leave scanner top open. rplug to power. wait til machine demands carts. reinsert and secure the carts. close cover. answer questions on display. set date and time again in case its not displayed.
If you still receive message use another cart of a diffrent brand. There are many generic carts with bad construction and bad ink out on market.
Best way: refill original brother carts. drill a 2mm hole on top into the brand name (O of brother). refill C/Y/M with a mix of 2ml 85%-glycerol (glycerin alc.) from drugstore and 10ml of DYE ink (shake well before refilling). For BK use 15ml DYE ink mixed with 1.5 ml gylcerol
shke very well before refill.
SOURCE: Brother MFC 5100C making white line in printing
The printhead is probably clogged. You may be able to clean it, by removing the mechanism and soaking the actaul printhead in a solution of white vinegard or you may have to replace the printhead. A web search may result in instructions on how to remove the head. Prinheads appear to still be available via Ebay and others. They run about $60-70 and if you have a bit of tech abilities, replacment should be relatively easy to do yourself. Not sure about finding a repair center that will do it for you or what the associated cost would be..
SOURCE: oh brother
I don't think there is a reset procedure for resetting MFC 3240c cartridges.
Professional refill facilities use a code reset device on cartridges.
Users that want to refill their own cartridges often use a piece of cellotape or plastic bag to cover cartridge sensor. This can damage printers head if ink goes too low and printer keeps printing.
My suggestion: stay away from troubles and buy original cartridges.
Here is a link on howto:
Reset ink sensor for Brother MFC 3100C - fixyourownprinter.com
