SOURCE: instructions on how to insert sim card
hello. there is often a diagram which shows u how to insert the sim card. it will be a little diagram of a box shape with a **** on one side, as ur sim has a **** on one side too. try looking for it. the sim insertion can be under the battery, or more rrarely- thru the side of the phone. dont get confused with where the memory card fits, it is much smaller in size.
SOURCE: Insert SIM Card message in nokia 6080 though SIM is inserted
May be its detecting your sim card properly. Check your sim card in another handset. Verify if its the propbelm with sim card not your handset.
SOURCE: my phone nokia 5200 is says insert sim even i have
you can also use the a peper paking on a som card other wise change your monile huddy
SOURCE: nokia e65 phone is stuck on offline mode.
hi thanks for using fixya!
On this kind of error, I suggest you should bring your Nokia E65 to a Nokia Care Center in your area to further check the software error.
If you need further assistance, let me know. Please rate me! thanks!
SOURCE: sim card not valid
Friend i have same cell phone and i am also facing this problem but dont worry
go to network menu and select Automatic network that problem will be solved if not them show it in to nokia care
