Set the time on your Baby G by switching to time mode. The button on the bottom left-hand side of the watch is the mode button. Pressing it once to will set the watch to time mode. The time digits will begin to flash.
2Start by adjusting the seconds. Press the button on the top-right side of the watch once. The second digits will start to flash. Press the bottom right-hand button until the correct second time is displayed. Hold down the button to cycle through the digits. Once the correct time is displayed, press the bottom left-hand button and the digits will stop flashing. Press the bottom left-hand button again to set the hours.
3Follow the same procedure to change the hours setting. Set the time and date by cycling through the digits in the following sequence: seconds, hours, minutes, year, month and date.
4Press the bottom right-hand button to set the seconds to 00. When the second display is between 1 and 29, the digits will change to 00. If the display is between 30 and 59 seconds, the seconds will revert to 00 and one minute will be added to the minutes display.
5Change from an a.m. to a p.m. setting by pressing the button in the middle of the bottom of the watch when any of the time display digits are flashing.
You are witnessing what is called the EOL or end of life indicator. Relax, it's your battery not you! Better watches have this feature. You will notice the time remains correct even if the seconds hand jumps 4 seconds. Some watches it is 2, some 3 seconds.
Many high end quartz watches have a feature called the EOL or end of life indicator. This causes the seconds hand to jump 2, 3 or 5 seconds depending on the make of watch when the battery life is low. The watch will continue to keep accurate time until the battery dies completely. So, when you see your seconds hand jumping multiple seconds it is time to get a battery.
You need to replace battery. Q/A from swiss army website. Q. How do I know when the battery needs changing? A. In select models, the battery end-of-life indicator signals that the battery should be replaced within two or three days. When the battery is low, the second hand stands still for 2-4 seconds, and then speeds up to the correct time. This indication will last for approximately one week, and then the timepiece hands stand still.
For sure you know EcoDrive watches are powered by light and all advertisements says: you will never have to change the battery. That's right - you will never have to change the battery, because there is no battery as we know. In your watch you have CAPACITOR, and it is the cell (sort of battery), recharging itself from the light consuming plate underneath the dial. Capacitor is not timeless, so, you have to replace it anyway. Find your nearest watch repair shop and ask for replacement.
Your watch is fitted with EOL feature and let you know about insufficient battery power by moving seconds hand by 2-5-second increments.
You have about two weeks time to change the battery from the EOL engagement or your watch will start to malfunction or even stop.
In this case you will have to reset your watch after battery replacement.
EOL = End Of Life (relates to battery only).
Jumping seconds hand means it's time to change battery.
Rate me, plz.
This is warning: it's time to change the battery. Your watch is fitted with EOL (end of life) feature and this is how the low battery power is displayed. However, the watch will keep running correctly for about two weeks.
Your TAG is fitted with EOL (end of life) feature. This is the cause of
that 4 seconds interval movement of seconds hand and thus indicating
the time for battery replacement. The timekeeping is not affected by
this- it is just warning to replace battery a.s.a.p. Find your nearest watchmaker and ask for battery replacement.
