Computers & Internet Logo
Posted on May 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i press power on button of cpu for start the system, the systems has start but suddenlly shut down of off whole systems. give me slolution for fix this problem
furirwai matsiwe
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 29, 2015
furirwai matsiwe
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
339
Points
I had a problem with my IBM but i just changed the power supply an it was ok, then I had the same problems with a different machine but its a similar IBM version Itried to change the power supply but it didnot work out.
Matthew deSilva
Level 3:
Master:
  • Master 375 Answers
  • Posted on May 06, 2011
Matthew deSilva
Master
Level 3:
Master:
Answers
375
Questions
0
Helped
64080
Points
1156
Hi Vedant,
first of all I would check the cooling fans, particularly the one for the cpu, you will see if it is spinning if you remove the side case. (DONT TOUCH ANYTHING INSIDE WHILE THE PC IS SWITCHED ON) If the fan is spinning ok, then check for dust build up around the cpu cooler. If it needs cleaning, switch the machine off first and unplug from the power supply. Touch a bare metal part of the case before attempting anything to discharge any static electricity you have in your body. Clean any dust build up away and try booting the machine again. If still no joy, Check your RAM modules, try removing them one at a time to see if one is faulty. If you have more than 1 stick of ram, make sure when you remove one, to put the remaining module into the slot closest to the cpu.
I hope at least some of what I said turns out to be helpful to you
Shawn O'Halloran
Level 2:
  • Expert 345 Answers
Shawn O'Halloran
Expert
Level 2:
Answers
345
Questions
0
Helped
97328
Points
966
Overheating. The shutting down is a fail-safe. You need to first open your cabinet and check your fans and make sure that your computer aren't filled with dust. If it is blow it out with air duster and it should solve the problem.
If your fans have failed, you'll need to replace them. If they haven't, your next step is to increase their speed. The utility below will monitor you temperature and increase your fan's speeds to keep the system cool. If you are unable to cool your computer down to the point where it stays on, your power supply had gone bad and needs to be replaced.
http://www.almico.com/speedfan.php
tip
Safe and easy shut down for regular Desktop users
Hai from Vishu
For Desktop Systems
when all applications are closed user can depress power button once for a second located on front panel of CPU(not the reset button) to initiate shutdown at one go when system is to be shutdown.( Applicable for all P4 cpu ONLY and not for older system where this action shuts down CPU immediately...)
on Jul 24, 2010 • Computers & Internet
I have dell inspiron 1525.I am from India. I have two problems. First I have a sim card slot in my laptop and ai don't know how to activate it. My other problem is serious one. My laptop unexpectedly...
Dell has a series of tests for a system's hardware called the PSA+ Diagnostics. You can run these tests by performing one of the following actions:
  • Hold down the key while pressing the power button.
  • Turn on the system, press at the initial Dellâ„¢ logo screen, and select Diagnostics from the boot menu.
  • Disconnect the AC power and remove the battery. While holding down the power button, insert the AC connector into the back of the system. The system then starts and the message Diagnostic boot selected displays. The system then launches the PSA+ Diagnostics.
  • As for the laptop shutting down, that usually indicates your CPU (Central Processing Chip) is overheating. This is caused by dust or defective CPU fan or heat-sink.
My cpu is not shutting down even i shut down. But my monitor showing shuttingdown and display is turning off as if like the system is shut down Still cpu is running. and also my monitor is not turning on...
Shut down by holding in Power button for 5 secs... press F8 continuously on start up, go into Safe Mode with Networking.. have a look around at some of the Devices in Device Manager, check Drivers, also default to normal mode in Bios/Uefi
2answers
Have a toshiba laptop tuan on work for about 10 minutes and power shuts off what good be the problem
The Toshiba could be overheating and then shuts down. It won't boot up again until it has cooled down.
If this problem is not fixed the the CPU will eventually fail. For details to fix this problem, please click on this link and follow my instructions :-
http://www.fixya.com/support/r5959377-overheating_computer
2helpful
2answers
I am having problem in starting up my system.once system has shutdown ,it fails to start immediately after pressing the start button.even after 2-3 hrs it does not start on pressing the start button.but...
Sir,
Let me tell you that do not use UPS current on to the computer as the current in UPS is (AC) it would blow whole of the power supply or might effect to your Computer processor. As now you are suggested to get new power supply. hope fully this would work
3answers
System over heating
Simple reason is Replace your SMPS .
Setup powering down after 5 minutes of being on.
Enter you're bios & head to CPU section. There should be a section to check CPU & motherboard tempture. Sit back & watch the temp settings. (Check for over-heating which can & will shut down the system). It's best to do this with the case closed. Normal operation.
Did you add thermal grease between heat-sink & CPU. Same can happen if memory over-heats.
My home pc trouble in windows xp professional
Hi chirutha,
Which version of Windows are you running? I would suggest running System Restore to a point maybe a week ago and then trying it again. You can find System Restore from your Start -> All Programs -> Accessories -> System Tools menu. System Restore for Windows is non-destructive and won't delete any data files (music, pictures, documents) that you've put on the computer. It's also reversible.
You can also access System Restore directly from booting into Safe Mode (after the system POST startup messages run when the computer is booted up, press F8 until the Windows Boot Menu comes up and select Safe Mode).
If you can't power your computer down, hold your breath and then hold the main power button for five seconds and it will shut down.
Ben
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
