Hook up your Ps3 to your Tv with the AV cable turn off Ps3
After the console is off, turn on Ps3 but hold down the power button till you hear 2 beeps. it takes about 15 seconds, After the second beep release the button and then power up Ps3 again. This basically refreshes the source settings and will allow you to use your AV cable.
Any questions let me know.
Hello there,
There is no way to connect an AV cable directly to a PS3; however, you can purchase a special cable that convert the HDMI to AV. Here is one such cable.
http://www.amazon.com/Universal-S-Video-Audio-Cable-GameCube/dp/accessories/B000IAPGII
I hope this has helped! Thumbs up are much appreciated.
SOURCE: ps3- hdmi to av
unless there is a switch on the ps3 itself to change to normal tv, you may have to reconnect the ps3 via HDMI and change the screen resolution back to 480p or change the settings in the setup from hdmi to av.
SOURCE: My PS3 hdmi cable does not work
First off, if you want to use the hdmi remove the supplied composite cable from the back of the ps3.
You don't need both plugged in at the same time, and I'm not sure with the ps3 but some video devices will not enable both at once.
Have your tv selected for whatever hdmi input you have it plugged into. They should be labeled where you plug them in.
With the unit in standby, switch off and red light in front, hold the power button by the disc tray for 3-5 second. You will hear it beep, after the initial turn on beep, then you should see a display set up screen.
If you switch back to the composite, you will have to do this over again.
SOURCE: PS3 HDMI cable no signal to tv
by new 1ns i had the same problem i bought new 1ns it worked just fine
HDMI is available in several versions. The PS3 is compatible with HDMI version 1.3 or higher, which will take full advantage of Blu-ray Disc™ high-definition video. There are also "Type A" and "Type B" connectors. The PS3 uses the 19-pin Type A connector, which will allow resolutions up to 1080p.
The HDMI cable is not included with the PS3.
If you are using an adaptor (i.e., HDMI to DVI converter), try bypassing this adaptor and connecting the HDMI cable directly into the display.
Try connecting with the supplied AV Cable instead of the HDMI to see if you can get a successful installation. This will help determine where the problem may be with your particular HDMI setup and/or equipment.
Some older HDTVs may have issues with the copy protection protocols (HDCP) causing the handshake not being communicated between the TV and the PS3. Try resetting the TV by turning the TV and PS3 off, then unplug the TV power cord from the outlet and plug it back in. Then turn your TV and PS3 back on and see if the picture appears.
Press and hold the power button until
the systems shuts off. (wait 2 seconds)
Press and hold the power button again
until you here 3 beeps. Let go. Make sure that you are switching your
TV from HDMI to AV and vice versa.
It should ask you to connect your
controller via usb and press the PS button in
the middle of your controller. There
will be a menu with 6 options.
Try 1.
If you are able to get the AV cables to work with this method, try setting your HDMI up as you did before.
If you cannot get HDMI to work, then your output has gone out. You must use the AV/Component cables.
If you get no display at all but the system appears to be responding normally (outside of the display) then:
You have what is commonly known as the
"Green light of Death."
It is when your system powers on and acts normally but no display.
Your GPU (graphics chip) has cracked or become damaged and will need
to be sent in to SONY. You can try a 3rd party technician, but this
repair has a very very low success rate.
