The green blinking light is telling you the error code. count the number of blinks and make note of any sequence. Then google your make and model with blink codes added to the end. This will lead you to sights that will tell you what the error or blink code means.
could be a lot of things really. when you replace the bulb, there is a switch that will prevent the tv from turning on if the cover isn't sitting correctly, by moving it that might have shifted so it would blink, but not turn on. if not, well get it serviced, sorry
after holding down the menu and device the led will blink a two digit error code such as 3 blinks pause then 4 blinks then repeat that sequence a couple of times. Need that blink code to help let you know whats going on. The 34 code means lamp abnormality which translates to the power Pwb capacitors have most likely failed.
The set is trying to tell you somthing by blinking this light. And the bad news is that it's sayiny the DM board is not booting up, there are several problems that might cuase this all from bad capacitors to a shorted diode or a compleatly replacing the DM board. but all these are not for the weakend tv tech this one has to go into the shop
