Get the ATG AK1 Un-Tethered Systems
Better than Canon WFT.Simple to set-up & use.Has wireless radio flash plus dual live-view.
Configuring communications settings in FTP mode1. Select [Address setting] with the camera's Quick Control Dial.
2. If you choose [Disable] for DNS server setting, enter IP address. For [Auto assign], enter server name. For [Manual setting], set up IP address.
3. Set up [Port No.] usually at 0021.
4. Configure [Proxy server].
5. Configure [Login method].
6. Set [Target folder] to [Root folder] or select folder using [Select folder] menu.
7. FTP server connection is established.
Note: Settings can be stored in the camera.
Configuring automatic image file transfer in FTP mode1. Select [Set up] in [WFT settings] menu.
2. Choose [Automatic transfer].
Configuring communications settings in PTP mode1. Select [OK] from Pairing screen.
2. Start WFT Pairing software on PC.
3. Double-click the icon inside PC task bar.
4. Select the WFT-E2/E2A/E3/E3A/E4/E4A [MAC address] you want from on-screen list of cameras.
5. Connection to camera is established.
Remote control of cameraOnce you start EOS Utility, you can control the camera remotely, using all available functions.
