Disney Mix Max Digital Media Player Logo
Posted on Aug 12, 2008
My mix max player doesn't charge
I plugged it in but it won't charge and the ubs symbol doesn't show up
  • Anonymous Jan 01, 2009
    When we first received the mix clip player we charged it with the USB port on the computer and my daughter LOVED listening to her clips, but when the battery ran down and we tried to re-charge the battery NOTHING happens when we plug it into the USB port.
  • tiggerpa69 Apr 09, 2009
    I have the same problem with mine, although with mine I don't see any way to unplug the battery from the board to charge the battery. Any help is appreciated!!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 09, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3238
Points
13
I have seen this problem before with these units. It is generally caused by not following instructions when disconnecting the unit from the usb cable. The software interrupts the charge port signal between the battery and the dci processor. The unit will function just fine and nothing will seem wrong until the battery runs out completely. There is a simple fix for this but it is not necessarily an easy one.
1. Take apart the case of the unit. The easiest approach to this is to carefully pry apart the case at the sd card port with a small prying tool or butterknife. Take care with the large clips at the ends and corners of the unit that hold it together. You will most likely break every one of the smaller case clips on the sides when the case comes open. This is fine. The case will still hold together very strong with only the larger end clips. Remove any broken side clip pieces before putting the case back together so the case will close snug and tight.
2. With the case apart, note where the battery connects to the board and unlug it. Find a small ac adapter of about 5.5 volts to 9 volts but with no more than 600 milliamps output voltage. This will need to have a recessed tip on the male adapter prong like the one pictured in this url--- http://www.elderly.com/images/accessories/ACC/PS200R.jpg --- If you have technical knowledge in electronics and the right equipment then you can use an adjustable power supply with stinger tips to penetrate the battery plug. Note on the picture that the back of the adapter tells whether the positive or negative is located inside or outside the tip. BE SURE NOT TO CROSS THE LEADS WHEN TAPPING INTO THIS CONNECTION TO CHARGE THE BATTERY!!! Once the battery has died completely and the system becomes unresponsive the dci processor and charge port resets automattically but will not charge with out some power on the battery and since the battery is completely dead you must charge it for a moment in order to get the unit to acknowledge the reset and start taking a charge on it's own. on the battery red is positive. Connect the battery leads to the adapter using small wire leads for 30 secs. Replug the battery into the units board and turn on. the unit will power up and a message will come on screen stating that the battery is low and to recharge it.
3. Immediately reassebmle units case carefully and plug in the unit to a charger/usb cord. When unit fully charges ...unplug. That's it! (NOTE: IF YOU CHARGE THE UNIT USING A USB CABLE YOU MUST CLICK THE ICON IN THE SYSTEM TRAY THAT ALLOWS YOU TO SAFELY REMOVE THE UNIT AND THEN DISCONNECT OR YOU WILL SOON BE REPEATING THE ABOVE STEPS!!!)
  • leahallen44 Apr 21, 2011
    this was helpful but i am stuck on number 2
Anonymous
Level 1:
  • Posted on Jan 02, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3238
Points
9
I had the same problem with my mix max. I used the solution posted here by coreyjroman, except I just used a 9volt battery for my power source. I hooked up wire to the pos and neg sides of the battery and then plugged the other ends into thier respective sides of the mix max units battery pack plug. I charged it for 30 seconds and hooked it all back up like he said and it works just great! Thanks for the help! I hope my suggestion works for others too.
Anonymous
Level 1:
New Friend:
  • Posted on Apr 02, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3238
Points
What are the "wire leads" you guys are talking about?
**"Connect the battery leads to the adapter using small wire leads for 30 secs"
**"I hooked up wire to the pos and neg sides of the battery"
what type of wire is that? where can I buy it? If you know, please be super specific because I'm am almost completely useless when it comes to stuff like this, but my daughter really loved her Disney Mp3 player and she's really sad it doesn't work anymore.
Thanks so much!
    do u take the red and black wire's out of the white tip
Anonymous
Level 1:
New Friend:
  • Posted on Mar 25, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3238
Points
Wow thanks very much for the tips. I went with 9volt battery as well and it worked great. I was just about ready to scrap this player as the manufacture DigiBlue had advised it was out of warranty and there was nothing they could do and they offered no service. This was a great tip and saved my daughters player. Thank you very much!!!
James Hyde
Level 1:
New Friend:
  • Posted on Sep 05, 2016
James Hyde
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
3238
Points
Same for me. made my new mix max work that was dead out of box. Thanks
Anonymous
Level 1:
New Friend:
  • Posted on Nov 29, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3238
Points
Worked for me too!! On both of our Mix Max's!
Anonymous
Level 1:
New Friend:
  • Posted on Apr 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3238
Points
2helpful
3answers
How do i download music on my mp3 player?
How to Put Songs on Disney Mix Max
The Disney Mix Max portable media player is capable of playing audio files in the MP3 format. It can also play videos formatted as WMV and display photos formatted as JPEG. You can convert audio files into MP3 using the Disney Mix Max software -- Mix It Plug-in. The plug-in works with Windows Media Player 10. This software CD came with the player and is not available online. To download music to the device, you can use Windows Media Player 10 or Windows.
Things You'll Need:
* USB cable
* Mix It Plug-In installation CD
Instructions
Convert Non-MP3 Files
Install Mix It Plug-In. Insert the Mix It Plug-in installation CD into the computer's optical drive. Click "Install Mix It Plug-In" when prompted. If no screen opens, double-click on the "My Computer" icon. Double-click on the installation CD icon. Then double-click on the setup or installation file; this file is often formatted as EXE. Select to have the program saved to your desktop. Then double-click on the desktop icon -- "disneymixitplugin" to open the setup wizard. Click "Next" in the setup screen. Follow any additional setup prompts.
Open Windows Media Player 10 and create a playlist. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Open Mix It Plug-In. Select "Yes" when asked to save analysis information for your music files. The software will analyze each track's compatibility with the Disney Mix Max player.
Press "Go!" to start the conversion process. Once the process is complete, an inactive "Go!" will be displayed. All music that has been converted is still listed in your Windows Media Player 10 playlist. You are now ready to download music to the player using Windows Media Player.
Open Windows Media Player 10 on your computer.
Remove the USB jack cover located on the bottom of the Disney Mix Max. Insert the compatible end of the USB cable into the USB port on the Disney Mix Max. Insert the other end of the cable into the computer's USB port.
Click "Library" and click a playlist name. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Select the "Sync List" tab and choose "Sync List" from the menu.
Verify the items to be synced to the Mix Max, or right-click on a song title and select "Delete" to remove it. Click "Start Sync" to download music to the Mix Max.
Windows
Insert the USB cable to the Disney Mix Max USB jack. Connect the player to the computer with the USB cable.
Click on the desktop "Start" menu and choose "My Computer."
Double-click on the "Removable Disk" that corresponds with your connected device.
Drag songs saved on your computer with your mouse into the Removable Disk folder.
Tips & Warnings
If you converted files using the Mix It Plug-In, you will need to use Windows Media Player 10 to sync them to the player.
I charged our Mix Max and it's "stuck" on the
Prees the restart button. If that doesn't work, let it die completely and plug it back in and let it charge completely before turning it back on.
3helpful
3answers
My daughters mix max will not come on, this is the second one that we have gotten with the same problem.
When I first received, the player, it had to be initially charged before it would do anything, or even turn on. Once I allowed it to charge for about an hour, then it would turn on and I could see the charging lightening symbol.
Mix max wont turn on even though its chargeing.
if u just put it in and it says its ok to remove don`t remove it kep it in for like 5 min. then take it off the charger
Is there a plug in charger
You can purchase a Music Power Duet USB AC Charger for iPod and MP3 Players or Simitlar. I got mine from walmart, follow the link.
http://www.walmart.com/catalog/product.do?product_id=5750794
3helpful
2answers
I lost my disney mix max charger
There are several types of chargers you can use with the mix max....car charger, wall charger, USB to computer (FYI turn your computer off while charging and it stops), and my favorite - the speaker station. Just do a search for disney mix max charger on the internet, amazon, or ebay and several options will come up. I like the speaker station because it is easy to charge with it and lets my daughter use it as a stereo and dance unit if she wants.
2answers
Mix Max
Try pressing the reset button on the bottom of the player with a tack or paper clip. If you have a SD card try removing it and then reset the player.
Top Disney Audio Players & Recorders Experts
Alexander
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Disney Audio Player and Recorder Expert? Answer questions, earn points and help others
