Hello for N73 there is no such solution...But you can generate the current password by visiting mobile repairing shop.There they can generate the password with the help of repairing tools.But if you don't want to do such thing you can easily format the mmc by selecting "Format memory card">Menu>Tools>Memory card Folder>Option>Format.....you can do this if you don't need the data/files.Thanks for visiting fixya
After much experiments i found this: As soon as you insert the phone jack press the hash(#) key then all 6 program keys, hands free key, mute key lights up. It displays 5 options as follows main 3.80.40 1/5 soft 3.80.40 2/5 load 3.80.40 3/5 boot 2.00.00 4/5 ivanoe2 1024/128 5/5
If i press the OK button by selecting any of the option(by repetedly pressing the # key) nothing is happening.
Please help me what could be the next step????????.
Normally when you put a password on a phone, the ONLY way to get into the phone is to put in the password. If you don't remember the password, then you will need to do a hard reset on the phone. Unfortunately, this will erase everything on the phone.
Don't worry You can reset the Phone from the Password lock using the master reset code,It's Nokia or Alcatel Phone means get the master reset code from here
Unlocking4free and reset it......
If you have Rev 1.5 (x426) or earlier and most older models
Use the *#9998*3323# Trick (look for it on the forum)
The *#1111*WHATEVER# code will NOT work
If you have Rev 1.6 (x426) or later and most newer models
You MUST use unlocking software. Codes WILL lock your phone FOREVER
Locked: Return for Servicing
There is only 1 working solution, you must flash a copy of the firmware
that is not in the locked status. (Most) Unlocking programs will NOT
disable this issue, and your service provider cannot give you a code
If you do not plan to use your phone with another service provider,
there is no real point to unlocking your phone other than to sell it.
If you don't need to unlock it, don't take the risk of disabling the
phone altogether
The *#9998*3323# Method:
1. If you have changed your phone password, change your password back to the default 8 zeros (00000000).
2. Put a SIM card that is from a network other than the one your phone is locked to
3. When Incorrect SIM error comes up, type *#9998*3323#.
4. White screen will appear with an exit option. Press the right softkey.
5. From the menu that appears, select the Malloc Fail option. This
will reboot the phone and the normal service screens will appear.
6. Type *0141# and then press the green call key. "Personalization" or "Personalized" will appear.
7. Turn off your phone and put the original SIM back in.
8. Turn on your phone. You will receive a prompt to enter a password.
9. Type 8 zeros (00000000)
10. Completed. You have now unlocked your phone.
Thank you for using fixya.. Please rate me on fixya and provide testimonial if ever to continue my further assistance..
If you are locked out you can enter the wrong password several times and the phone will restore to factory settings. The downside to this is you lose everything unless you used the backberry server and saved!
Which phone is it?
