In that case, you need to reset your device. All the configuration will back to its default or factory setting then you need to configure it again.
Press the reset on the back next to the power for 10 seconds. The router will reboot and it will go back to factory defaults. You do not have to re install the firmware. It will just set everything to default and you will just have to set it up again.
If you hold the reset button in for around 30sec this will erase all the settings everything will be there but it will be like it just came out of the box.
