The water tank is either full or not positioned correctly. Empty the tank and/or make sure it is positioned correctly (should fit perfectly and not bump out from rest of unit).
If you have it connected to the drain directly, your tank may still be filling up unless you have the PUMP button pressed (and PUMP is showing in the LED screen).
Good luck and please rate me.
-mark
Testimonial: "Very helpful."
The unit beeps and when we press Pump button nothing happens.
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
