Hi, continuity check your fuses, they're tiny green SMD fuses located near your dock connector. However, it sounds more like a bad internal connection than a fuse. This was a problem that plagued ST1 sirius radios: solder on the chips' pins would crack, and when the unit heated or cooled it would no longer make a connection, thus requiring a reboot. Long story short, most of them can't be fixed without reworking the connections (and that's a lot of effort for something that will break again).
I'd advise you to send the unit back to sirius if you're still under warranty.
