GoVideo Go Video DVD/VCR Combo Logo
Posted on Aug 11, 2008
Display problem Attempting to watch movie DVD on Go Video model DV2130. There is a large rectangular gray area displaying on top of the DVD movie. You can see through the gray area but it encompasses approx 60% of the screen surface. How do I get rid of this gray rectangle?t
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 11, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
88
Points
Hit the display button
I cannot get the DVD player to display the movie in color. It is only showing in black and white yet it is a DVD in color.
Color system may be different. If say DVD player set for PAL and DVD is NTSC and TV is Pal you will get this effect.
tip
How to Rip DVD and import DVD Movies to Sony Ericsson Vivaz(pro) for watching
Quoted from: http://dvdrippingsoftwares.com/convertdvd/dvd-to-vivaz.html
This article will walk you through the process of ripping/converting DVD to Sony Ericsson Vivaz(pro) so that DVD movies (including homemade and commercial DRM protected DVD) can be played/watched on your Vivaz.
Sony Ericsson Vivaz —The best experience for Symbian Series 60 so far
The Sony Ericsson Vivaz display is a 3.2-inch 640x360 resistive touchscreen, with a sharpness to the display quality of a much higher end phone thanks to the onboard PowerVR SGX530 GPU. The bundled 8GB memory card for ample storage is designed for its 8.1 MP camera that can record 720p HD video. And we should absolutely make good use of its 3.2in, 360 x 640 resolution screen and 8GB memory card for watching DVD movies other than shooting HD videos.
Sony Ericsson Vivaz video/audio format:
- Video format support: WMV, RV, MP4, 3GP
- Audio format support: MP3, WMA, WAV, RA, AAC, M4A
How to play/watch DVD movie on Sony Ericsson Vivaz –Convert DVD to Sony Ericsson Vivaz MP4/WMV/3GP/MP3
Here we present you Wondershare DVD Ripper platinum to convert DVD to Sony Ericsson Vivaz.
1. Free Download Wondershare DVD Ripper platinum
2. Load Your DVD to this DVD to Sony Ericsson Vivaz Converter
Click "Add" button, you are allowed to import DVD from local disk or CD-Rom , you are allowed to load DVD Rom, DVD folders, ISO files and IFO files respectively.
3. Select the output format for your Sony Ericsson Vivaz
4. Start to convert DVD to Sony Ericsson Vivaz
Click "Start" to start conversion. All the tasks of conversion will be finished at fast speed and high output quality.
That's it. Now, you have already convert DVD to Vivaz-friendly format and then you can Copy the converted DVD Movies to your Sony Ericsson Vivaz for watching for fun.
___________________
dvd to sony ericsson xperia x10
on Aug 29, 2010 • Cell Phones
tip
Best DVD to Xbox 360 Converter: Help you watch DVD movies on Xbox 360 easily
You can watch movies on your Xbox 360 since its integrated Xbox Live service allows you to download movies, but excluding DVD movies. Sometime you may want to take a break from playing game to watch your favorite DVD movies on your Xbox 360. But how could this happen?
It is no longer a problem to watch DVDs on your Xbox 360 now, if you have an application of DVD Ripper. It helps you easily rip DVD to AVI, MKV, MP4, WMV, and 3GP, just name a few, while maintain the high quality.
Now, let’s figure out how to put DVDs on Xbox 360 with DVD Ripper.
1. Download Daniusoft Best DVD Ripper, install and launch it.
2. Upload DVD to DVD Ripper by clicking ‘Add’ or ‘File’. You can select DVD Folder, ISO file, or IFO file respectively. And DVD Ripper can automatically scans and displays the files.
3. Select proper output destination and your desired output format. Here I select “ Xbox 360 Video – Windows Media Video (*.wmv) from the drop-down list of “Profile”.
If you want to personalize your DVD movies, just click ‘Edit’ and you can create your own videos with powerful editing functions of this DVD Ripper.
Crop – Crop the frame size of the video and get the part you want.
Trim – Set start time and end time or just move the sliders to convert the particular part you want to put on your Xbox 360.
Effect – In addition to configure the brightness, contrast, saturation, you can add special effects to your DVD movies such as Emboss, Gray, Negative, and Old Film.
Watermark – Add special text or pictures watermark to your videos.
4. Start to convert by clicking ‘Start’ button. You can set the action when the conversion completed like shut down the computer, open the output folder.
Within several minutes, you can find your converted DVD movies or videos in the output folder. Simply drag the converted files to your Xbox 360 and be ready to watch DVDs on your Xbox 360 on the move.
Is it compatible with L G tv? I cannot get mine to show movies or activate setup mode.
You should press SOURCE option of your remote and select DVD . When you finish watching your DVD, select source again to go back to TV
My Go Video DV 2130 remote either no longer works or cannot be programmed to my Toshiba tv. There code listed in the instruction book for Toshiba does not work. Do I need a new remote or a different...
Have the remote tested--most shops will do this for free--point the remote at the tester and press a button and tester reacts.
This can also with most digital cameras be done---in a very dark room with camera on watch its display screen and point remote and press buttons--should see some tiny flash of light on the camera display screen---cheaper to fix the remote then get another--most of the Go Video units were made by Samsung.....
While playing video aur audio...video suddenly stops like pause and make large sound than starts again.and if watching movie it repeats after every 15 minutes...........model hp pavilliondv4...
you need to update the direct x and update video display card drivers.
download http:// microsoft.com/directx
check your which directx version you have
type in run dxdiag.
DVD WS does not display right on Samsung 40'' HD 1080P LCD TV
Check the aspect ratio of your widescreen DVD. I'll assume that your flat panel TV is widescreen, which would mean it has a ratio of 16:9. Some movies are even wider than that (i.e. 2.35:1), so it would be normal for you to see black bars at the top and bottom. Look for a WS DVD described as 16:9 (usually shown on bottom on back). This should fill your TV screen and not distort the image. If you still see the black bars, you will need to check your DVD menu settings for widescreen aspect, and supply more info on the DVD player and TV.
Blue Box in the Corner won't turn off!
That problem might be on the remote of display settings on video display. There is one button that will turn that off. Try Display Settings
Top GoVideo Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
