Armitron Digital Sport 406623BLK Watch Logo
Posted on May 04, 2011
How do i set the time and date for my watch - Armitron Digital Sport 406623BLK Watch
1helpful
I have a 2003 Croton Belagio watch How do I set correct date?
To set the date on your Croton Belagio watch, you will need to follow the steps for setting the date on your particular watch. Every watch is different, so the specific steps will depend on the make and model of your watch.
Here are some general steps that you can follow to set the date on your watch:
  1. Locate the stem (the button on the side of the watch) and press and hold it until the display begins to flash. This indicates that the watch is in time-setting mode.
  2. Use the stem to cycle through the different settings, such as the time, day, date, and year.
  3. When you reach the date setting, use the stem to adjust the value to the correct date.
  4. Once you have set the date to the correct value, press the stem to exit the setting mode.
If you are unsure of how to set the date on your watch or if you are having trouble, you may want to consult the manual that came with the watch for more detailed instructions. If you do not have the manual, you may be able to find a copy online or you can try contacting Croton customer service for assistance.
1helpful
I need to change the date
Changing the date for the FT500WVB watch is easy. Just pull out the stem of the watch to its first stop. Then turn the stem counter clockwise a couple of twists and the displayed date will increment (that is increase) by one day and you will hear a little click. Keep twisting the stem counterclockwise and the date will increase by one each time with a little click. Stop when you reach the correct date and push the stem back in to its fully seated rest position. Note- be careful not to change the date when the watch displays a time between 9pm and 1 am as setting the date in this time range may cause the watch to increment the date at noon rather than midnight.
Note also that if you want to set the time you just pull out the stem to its second stop position and twist the stem to advance the position of the hands of the watch. Then when the time is set, push the stem back in to its lowest rest position. So remember- first stem stop sets the date and second stem stop sets the time. That's it.
Intercrew LED watch, model ic3905. How do I set time and date?
Setting intercrew led time and date - Fixya
www.fixya.com/support/t14276175-setting_intercrew_led_time_date
Sep 8, 2012 - setting intercrew led time and date no instructions to set time and date on LED Watch by INTERCREW - Watches question.
Intercrew LED - YouTube
? 1:57
https://www.youtube.com/watch?v=bR9oGWDTwxs
Jan 25, 2012 - Uploaded by CoolWatchDanmark
Review af et af vores meget popul?re LED-ure. Intercrew LED. ... ????????
Dec 24, 2013 • Watches
2answers
How to advance date 4 or 5 days on a Timex T40021
This watch should have a "quick set" date function that lets you advance the dates by turning the setting crown. To get the watch in this mode, pull the set stem out half-way. At that point, turning the setting crown will advance the date on the watch without turning the hands. One some watches, finding the right position for the set stem can be a bit tricky--either it's not out far enough or it's out just a bit too far and the time hands turn. You may have to try pulling the stem in and out a few times to get it just right.
A word of advice: watches are generally designed to advance the date, not to turn it back. It's suggested that if you need turn the date back, you actually advance the date wheel up to 30 days to get to the date you want. Some watches do permit you to turn dates backwards, but I prefer not to risk the chance of hanging up the little springs and mechanism that are designed to advance the date indicator.
One final note: I have serviced several Timex mid-size (ladies or kids size) Expedition watches that lack a quick-set date. Many Timex watches in that size do have a quickset date like I've just described to you, so I have no idea whether these watches happen to have a cheaper movement or if they have some internal damage (it's been the same model each time). At any rate, for those watches, I have had to use the incredibly slow and painful process of advancing the time 24 hours to advance the date. With those watches, if the date is too far advanced by a day or two, it may be easier to stop the watch for 24-48 hours until the date is correct, rather than spend a huge amount of time spinning the crown to advance the time. Hopefully, your watch will have the more sophisticated movement, though.
How do you set the time on an Armitron 165 wrist-watch?
Hi wtgillo,
Hi there I see that you are in need of assistance setting time on your Armitron Wrist watch.
I would be more than glad to give you details on how to, Please see steps below.
  • Your Armitron Watch will have Four Button on the side of the watches rim.
  • Button on the upper Left is MODE.
  • Button on the lower Left is LIGHT.
  • Button on the upper right is DATE.
  • Button on the lower right is Alarm.
See Steps below:
*Setting the time*
  • Press and Hold down the Mode Button til the Hours flash
  • Then push Alarm Button to set the Hours
  • Press and Hold down the Date Button till the Minutes flash, then push D/Alarm Button to set the minutes
  • After setting the minutes on your watch, Press date till you get the month flashing push Alarm to set the month
  • Press the Date again till the Date flashes, then push Alarm to set date
  • Press the Date again till the Date on your watch flashes, then push Alarm to set the date
  • After setting everything push the Mode Button again just once to set everything or finalize your settings on the watch.
I hope that this will be of help regarding your query on how to set the time on your Armitron watch, I also included the setting of the time and date just for further details.
Have a nice day,
mvincentc
2helpful
Do you have directions for armitron mens pro sport watch 49/1000
Hi robinmsavage,
I will be glad to help you with your concern regarding your Armitron Wristwatch, what exactly would you be experiencing? cause I only put info on how to set time and date on the Watch.
Please see below steps:
See Steps below:
*Setting the time*
  • Press and Hold down the Date Button till the Minutes flash, then push Alarm Button to set the minutes
  • After setting the minutes on your watch, Press Date till you get the month flashing push Alarm to set the month
Thank you for choosing Fixya,
mvincentc
0512037FA Wrist Watch: how do you set the date in the window of a seiko 6...
mcdevito75 here, The stem should have 2 positions to set the DATE without haveing to cycle the watch 60 times. Slip a finger nail just under the crown and gently, gently lift the crown to it's first position, it may take practice so be patient, once in it"s first position you can easily change the DATE, change it to 1 DATE before the DATE you want. NOW! push the stem back in and then pull it out to set the proper DATE and time of day, your watch is set and will change on time, around Mid Nite.
Tozai digital watch-setting correct time/date
I need to correct the time/date setting on a tozai digital watch.
Apr 05, 2009 • Watches
7helpful
Rolex watch yacht master set time
Let me start by saying that I own this watch and LOVE it!
To set the time you need to pull the crown all the way out to the furthest position.
To set the date you need to have the crown in the position in between the "winding" position and the "time set" position. Basically, pull the crown out till you hear/feel 1 click to wind, 2 clicks (total) to set the date, and 3 (total) clicks to set the time. I always set the date first to 1 day behind the current date. I then move the crown out to set the time so that I can set the watch to either AM/PM depending on the actual time. For example, I set my Rolex today (the 5th of January at 3pm - just an example). I would first move the crown to the date setting function and move it to January 4. I would then move it out one more position to set the time. I would go around the watch until the date changed to the 5th and then go around from 12 to 12 to change from AM to PM. I would then move it to the 3 and then I'm all set. This is helpful because it will ensure that your date will correctly change when the day changes and not be 12 hours behind.
Jan 03, 2009 • Watches
Top Armitron Watches Experts
Gene Lawson
ADMIN Andrew
ADMIN Andrew
NOEL
NOEL
Are you an Armitron Watch Expert? Answer questions, earn points and help others
