Hello & Welcome to FixYa
F35 error means that there is some sort of issue
with the steamer electronic board and analog pressure sensor has gone bad.
Check that the hose is firmly attached with the washer and is not blocked. You
can also check the water level pressure switch operation. Please get back to me
if you have any other questions.
Kevin
Kevin
Hi
The
"F35" error code is indicating a problem with the ANALOG PRESSURE
SENSOR switch operation .There could be a blockage in the air dome or pressure
switch hose. The pressure switch is located underneath the main top on the
right hand side. (See image) The air dome is located on the back of the tub on
the left hand side. If the pressure switch hose and the air dome is clear of
any blockages the likely failure is the water level pressure switch (key#20)
part# W10156252. Replacing the pressure switch will likely resolve the
"F35" issue.
Please
get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
