SOURCE: Erasing Folders
Press the erase button, and delete will flash. Then press and hold the erase button
SOURCE: rca mp3 model m202a
Reformat the player, try again
If problem still persists, get a firmware upgrade
SOURCE: RCA RP 5012B digital recorder
It is not possible to download the sound files in their digital forms with this model of recorder. The only way to transfer the recordings is to connect a male-to-male 3.5mm (1/8") plug from the recorder to the line input of the PC (as was formerly mentioned) and record it onto the PC in real time. I've done this with mine and it works fine...it just takes longer to do than tranferring the actual digital file to the PC. A good MP3 recorder for the PC is Audio Record Wizard. http://www.nowsmart.com/arwizard/
The full version costs $25, but I think it's worth it.
SOURCE: Can't upload audio from my RCA RP5022B Digital Voice Recorder
all you have to do is install the DVR manager program that comes with it in the setup file. then you go to the drive on the bottom left that your file is saved in. then click on the file you want to transfer. after you do that you go to FILE----->MAKE .WAV FILE and choose the save location and it will transfer it to your computer. then you can use a program like audacity to listen to the file.
