Kenmore 98702 Stacked Washer/Dryer Logo
Posted on Aug 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dryer door My dryer door will not open. I'm guessing my dryer is probably a Kenmore 98702 Stacked Washer / Dryer. It is a Kenmore, stacked model in any case.
Anonymous
Level 3:
Master:
  • Master 623 Answers
  • Posted on Aug 12, 2008
Anonymous
Master
Level 3:
Master:
Answers
623
Questions
Helped
177471
Points
1550
I would try to run the dryer again. If that doesn't work, it's time to call the repairman.
2answers
My kenmore 98702 stacked washer/dryer washer lid does not stay open
Underneath the top unit (the dryer) there should be a spring loaded catch that holds the door open. See if it is gummed up and stuck or possibly broken off.
2answers
98702 Stacked Washer / Dryer Your question about 98702 Stacked Washer / Dryer has been posted. Mom has a Kenmore stackable washer. She ran water in for a load and the water ran out of the washer and onto...
Get the control panel off and remove the water pressure tubing. Blow it out and reconnect to pressure switch. Remove water so that pressure can once again build inside the tube. Retry>
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Washer works fine dryer does nothig
Looks like my Maytag. My dryer belt is broken so doesn't tumble. Check by taking two screws out of tilted panel and look at belt. If it isn't heating probably heat coil. If nothing probably electrical. Maybe door switch is open circuited.
Kenmore 98702 Stacked Washer/Dryer. Dryer making clicking noise
There may be coins stuck inside the tumbling vanes in the drum.
Kenmore 98702 Stacked Washer/Dryer Combo Model 417.98702890
There is an EXTERNAL fuse on the back of the unit.
Service manual is inside the machine's shell in plastic.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Kenmore model 98702
No - it is one body. it cannot be replaced - only repaired.
2helpful
3answers
HOW DO YOU TAKE THE DRYER OFF?
If it is stack from the factory (ie..came as one peice) you cant
Alexander
vince
