Question about Texas Instruments TI-84 Plus Calculator
How do I convert decimal to fractions, and fractions to decimal with this unit?
Let's take a simple example to understand.
# Convert 0.5 Decimal to Fraction:
0.5 = 5/10
gcd(5,10) = 5
0.5 = (5/5)/(10/5) = 1/2
Also, you can use online Decimal to Fraction Calculator to do so.
https://www.decimal-to-fraction.com/
Posted on Jul 26, 2019
    New Friend:
    Problem Solver:
  • 18 Answers
Decimal to fraction: Type in your decimal (i.e. .5) Then press [MATH] > press [ENTER] on [>FRAC] Then press [ENTER] again Example: .5>Frac 1/2 For a fraction to decimal: Simply type in the fraction and press [ENTER] Example: 1/3 .33333333333 (*Note that the decimal value is truncated to fit the screen)
Hope that helps! Have fun calculating!
Posted on May 03, 2011
6ya staff
SOURCE:
How do I convert decimals to fractions on the TI Math Explorer (No numbers associated with it - i.e. TI - 15)?
The way it works is as follow. If a result is displayed as a fraction you can convert it to its decimal representation. If you do nothing after the conversion, you can revert the decimal representation to the fraction.
Apr 29, 2014 | Texas Instruments Office Equipment &...
F-D key in Polynomial
The F-D key converts a displayed result from fraction to decimal and vice-versa.
If in the polynomial expression a numerical coefficient is a fraction just enter it as a fraction, possibly enclosed in parentheses. If it is a decimal number just enter it as a decimal number. Converting it to a fraction is not going to generate any more precision in the result. You lose precision when you go from fraction to decimal, but you do not make a number more precise by converting it from a decimal representation to a fraction.
Nov 16, 2013 | Casio FX9750GII Graphic Calculator
Can you convert a decimal to a fration on the fx-300MS scientific calculator? If so how?
To convert a fraction to a decimal or a decimal to fraction you use the [a b/c] key.
While converting a fraction to a decimal number is always possible, converting a decimal to a fraction may, at times, not be possible.
Sep 10, 2010 | Casio FX-300MS Calculator
How to convert fractions to decimals
To convert fractions to decimals, and decimals to fractions use the [a b/c] key. If the total number of symbols (num, denom, fraction bar) to display a fraction exceeds 10, the fraction is automatically converted to decimal format.
Jul 19, 2010 | Casio FX-300MS Calculator
I can't get the answer to display in decimals only fractions.
For converting answers in decimal to fraction or fraction to decimal there is a S<->D key above delete key.If the answers is in fractional form press this key and it will be converted to decimal form.
Jun 04, 2010 | Casio FX-115ES Scientific Calculator
Conversion of decimals to fractions 0.1666666666666666666666666 = 1/6
You can always convert a fraction to a decimal. The reverse may not always be possible. Look at the example on the screen capture.
You may be lucky and recover a fraction you have just converted into decimal format, but you cannot just write 0.333333333333 and expect the calculator to convert it to 1/3: The true fraction 1/3 has an infinite number of 3's after the decimal mark.
May 26, 2010 | Casio FX-260 Calculator
How do you change decimals to fractions on a casio
If you enter an improper fraction or a mixed fraction with the the [a b/c] key it will be displayed as a fraction. This result being displayed you can press the [F-D] key to convert the fraction to decimal. If you do nothing else and you press the [F-D] key again, the original fraction will be restored.
However, it seems that you cannot enter an arbitrary decimal number and convert it to a fraction. The [F-D] key seems to work one way : from a fraction to a decimal number. You will only recover a fraction if the original number was a fraction.
Jan 19, 2010 | Casio FX-9750GPlus Calculator
How to convert fraction to decimal
You can convert between Standard Form (with fractions and pi) or Decimal form by using the "S<->D" button. Use Mode 1 if you mostly prefer fraction answers and you can use the SD button to convert to decimal or use Mode 2 if you mostly prefer decimal answers and use the SD button to see the fraction.
I hope this helps and good luck!
Please remember to vote 51218db.jpg Thanks.
Oct 31, 2009 | Casio FX-115ES Scientific Calculator
I need to convert decimals to fractions
Press [MATH][1:ToFrac] to convert an aswer to fraction.
If you enter 18.52[ToFrac] [ENTER gives 463/25
[MATH][2:ToDEC] converts a fraction to a decimal number.
Hope it helps.
Sep 22, 2009 | Texas Instruments TI-84 Plus Silver...
HOW TO INTER FRACTION ON A TI-83
Once you enter a fraction the calculator calculates it and displays a decimal result.So basically you cannot do fraction manipulations. However you can convert a decimal result into a fraction. To do the conversion, you enter the decimal number then you Press [MATH] and [1]. ( -->Frac) The number will be converted.
Similarly you can enter a fraction to a decimal number (-->Dec)
[MATH] [2:] [ENTER]. But I see no point in doing that, because any fraction entered is displayed as a decimal number.
Hope it helps
Sep 03, 2009 | Texas Instruments Office Equipment &...
Texas Instruments TI-84 Plus Calculator Logo
2,196 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Ekse
Gene Pitts
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
