The password to the router or to the wireless? You should be able to go into your ipad, click settings, wifi, and select your wifi.
On the web page go to 192.168.0.1 and for the password type "admin" into the password line only and hit enter. should work just fine.
If you have not changed the default login to the router then the login is admin and the password field is blank.
However, if you have changed the default login and do not remember it you will need to press the reset button on the back to restore the router to it's factory default settings then you can use the login above.
Hope this helps!
