Samsung SCX-5530FN All-In-One Laser Printer Logo
Posted on May 03, 2011
Message appears- internal error wer off/on FM_List. c 311 RO
sana ullah
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 14, 2015
sana ullah
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
894
Points
  • sana ullah
    sana ullah Dec 14, 2015
    plz send mi this masg soulation
1helpful
Error code 311
The Error 311 indicates a communication error between the Mac and the printer. If you upgraded the Mac from Leopard to Snow Leopard, there could be older driver files for the iP4300 that are conflicting with the new driver. Therefore I would start your repair by trashing all of the Canon files.
The first step is to disconnect the USB cable between the printer and the Mac.
The next step is to delete the current printer queue for the iP4300. Open Print & Fax, select the iP4300 in the list and click the minus ( - ) button to remove the queue. You can now exit Print & Fax.
The third step is to remove the Canon files. These are located in HD > Library > Printer > Canon > BJPrinter. Select all the files inside this folder and trash them. Then empty the Trash and restart the Mac.
With the Mac restarted, you can now run the installer for the 10.6 driver you downloaded from the Canon web site. Ensure this driver is version 10.26.0.0.
Once the driver has been installed you can connect the iP4300 USB cable to the Mac again and open Print & Fax. If the install has worked, the printer should automatically appear in the Printers list (note that this can take several seconds). If the printer does not appear, click + to add and select the Default view. The iP4300 should appear in this view. Select it and click Add. You may get a prompt stating the printer is already installed. If so, cancel this install and try printing with the new iP4300 queue.
If the error message still occurs, then I would try another USB cable. They have been known to cause the 311 error.
3helpful
I am getting an error message "external device error" chain link 116-311 for xerox 6204 machine
"external device error" chain link 116-311 for xerox 6204 machine how to solve the proplem
Getting error 311 message Reference Oecc I have a VIP 612 receiver, unable to record
The 311 message means the HD is going bad. You will need a replacement receiver. Have you unplugged the receiver from the electrical outlet for 10 seconds and plugged back in? If you still can't record, please call 1-800-333-3474 to order a replacement.
6helpful
2answers
Canon pixma 620 error 311
If you double-click on the printer, there is written:
The printer is connected.
After a while the message "Error 311: The printer is in use or an error has occured." appears and no pages are printed...not all printer is capable on print server. just because it supports Mac on USB doesn't mean it will work on Print server
it seems that printer are not compatible
3helpful
Internal Error WER OFF/ON DRAM_FUNC.C 58 R how to be?
samsung printer clx-3160fn error DRAM_Func.c 58 R wer off
3helpful
My Xerox Phaser 6110MFP got error "Internal Error WER OFF/ON DRAM-FUNC.C 58 R". Cannot get solution from any sites. Can't use printer. Please help, thanks. [email protected]
DRAM TEST
Use this feature to test the machine's DRAM. The result appears in the LCD display.
If all memory is working normally, the LCD shows << O K >>
1helpful
Error code 05
delete all recordings from hard drive unplug the receiver from the wall for 5 minutes and plug it back in, if 311 error message appears call dish network
FM radio "Hard Error"
no hard means you have a internal hard drive problem if under warranty take it back
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
