Make sure the little white switch on the side isn't set to write protect the SD card. Try and format the SD card, it will erase whatever is on the card. To do this right click the SD card removable disk under my computer, then click format. I would make sure you select FAT16 in the options there. Then try to copy files to the card again. If it still doesn't work, try using the SD card in another machine.
If the card works in another machine, we know the SD card is good. If it doesn't work, you might have a bad card.
If the card works in another machine, try another SD card in your laptop, to make sure the laptop connector for your card is not bad.
