Question about Toshiba 50HX81 50" Rear Projection Television
After moved the TV, you can tell the top and bottom lins is not straight, tilt to the center screen
    New Friend:
  • 93 Answers
You need the Red Green and Blue lights realigned in the rear. Usually costs 200-500 and not worth it on such and old TV. Go to Wal-Mart or online and buy a new Plasma/LCD!
I’m happy to assist further over the phone at https://www.6ya.com/expert/steven_958e67a4edcc47d5
Posted on May 02, 2011
6ya staff
SOURCE:
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Back tilt is a manual round knob on drivers seat it just turns
It sounds like the inside of the recliner knob is stripped out. If you go to your local GM dealership and give them your VIN number they can order you a new one. Here is the removal and installation directions.
Driver or Passenger Seat Recliner Handle Replacement Removal Procedure
  1. Use a flat-bladed tool to remove the plastic center cap from the center of the recliner handle.
  2. Pull the recliner handle off the shaft.
Installation Procedure
  1. Install the recliner handle on the recliner shaft.
  2. Push the recliner handle firmly onto the recliner shaft until fully seated.
  3. Install the plastic center cap into the center of the recliner handle.
Hope this helped please hit the accept button and positive feedback is appreciated.
Jul 16, 2013 | Oldsmobile Silhouette Cars & Trucks
There is a partial black screen in the bottom center of the tv and I don't know how to make it go away!!!
That is your vertical linearity adjustment on the back of the TV, called Vert.Lin. knob, if you do not have one take it to a TV repair shop and they will fix it.
Good luck.
Nov 11, 2010 | Televison & Video
How to install QY6-0061-000 Printhead
You open the lid and wait for the carriage to come tothe center, remove all inks, lift the gray lever straight up and tilt the printhead forward from the top and lift straight out. The new one goes in bottom first and then you tilt back the top, lower the lever again and install the inks.
Nov 20, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Can am Hitachi 50GX49B rear Projection TV be diassembled to move it to an area where narrow stairs prevent the complete unit to be mover through this area? I have noticed that inside there are 3 screws on...
Removing the screen is your best bet -
1 Remove speaker grill
2 remove 4 screws holding the screen frame
3 then lossen the bottom corners where the screen meets the frame by pulling outward (some force is required) and work your way upwards towards the top (two people may be required for support)
4 tilt the loosened frame(20-30degrees) from the bottom up and the top shoul lift and seperate from the frame.
After the screen is of you'll be able to tell what to remove next.
Good Luck!
Sep 21, 2009 | Hitachi 50GX49B 50" Rear Projection...
Top Screen on DS only shows lines
I take it the item is a ds Phat??
Problem is the same if its a Lite just a different part.
DS Phat - you need the screen cable that runs between the bottom board and the top connsctor board.
DS Lite, the screen and cable are all in one, so you need a new top screen
Nov 22, 2008 | Nintendo DS Console
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Aug 17, 2008 | Televison & Video
Akai HDTV1080i Monitor
Can you tell us the exact model?
Dec 02, 2007 | Televison & Video
ILO 32"' TV as white lins across top
my ilo-2600 has lines across the top of the screen.
Nov 02, 2007 | iLO 2600 Television
Toshiba 50HX81 50" Rear Projection Television Logo
56 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
