I didn't do this in configuration mode in the Wifi Wizard. Thanks.
SOURCE: Do I need to purchase the Device Configuration Package?
Depending on what application your client will use, you will need to configure the scanner in which ever way suits your customer.
If you use a telnet client kind like wavelink, you can configure it from there. If you planning on using some other application that has not scaner api's, you will need to use datawedge which is available as a free download from symbol support.
The DCP is normally available free of charge, however motorola has changed the downloads policy for dcp and depending on the version, you may need to provide them with information of the terminal and request the download.
I hope this helps.
SOURCE: Cannot read symbologie/BarCode: i25(interleaved 2
You will need to configure the telnet emulator from your pc first and download it to the terminal after.
Check the version of telnet emulator you have. To do this, go to the options menu on the emulator and click on about wavelink.
Register yourself on www.wavelink.com and download the same client version as installed on the terminal. (Don't forget to download the Active sync version.
Tweak all the configuration parameters on the emulator once you have installed it on your pc also enable i2of5 symbology and then download the config only to the terminal.
SOURCE: Cant activate PCCARD-PHOTON1 in Symbol MC9090
First thing is to run the wireless utility.
Start >> Programs >> Fusion >> WCLAUNCH
Once thats running an icon will apear in the task bar.
Click the icon and select "Enable Radio"
If you need any more help then please do not hesitate to contact us:-
[email protected] or TEL 01202 620955
http://www.biastechnology.com/
Suggestion,
First, go to ur Router Configuration Page. There are 2 pg into related WireLess Configuration Settings. So u find ur problem into the WPA security configuration is under the wlan Security section, and then you select WPA PSK (Pre Shared Key) and TKIP encryption for Lan security. As well as changing the WPA Mode to enabled, u will need to enter a WPA Pre-Shared Key. So u found, which is a Network key and why to need.
