My Dawlance split show FC option when turn on........How can it remove........
I m using dawlance , its not cooling properly, and its showing a fault <FC> , could you you please gauid me how to solve the problem???
If there is a button on the chord where it plugs in to the wall please press to reset the power, if that is not the problem check the circuit panel to make sure the power is on. Also check to see if there are any switches on the wall that operate the power.
Just found this and it worked! Hope it does for you as well:
There should be a button on the DVD remote control with a headphone symbol on it. Make sure the headphones are turned on(red indicator on earpiece) and push the headphone button on remote. The headphones will only work in the back seats of the vehicle. Once you have audio to the headphones, you should be able to hit the AM/FM button on the radio and listen to the radio while back passengers use the headphones for video.
[3] Find the "Recall" or "Setup" button on the Toshiba remote control. After you find it, press and hold down that button until the lights on the remote control turn on and remain lit. [4] Point the Toshiba remote at the device you turned on in Step 2 and press the button on the remote for that device. [5] Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed. OK.
can any one guide me about the function of remote control or having any klind of pdf for dawlance mogram user manual
