Question about Gateway FPD 1730 17" Flat Panel LCD Monitor
A spot developed in center of screen next day black lines across screen from the original spot
    New Friend:
    Problem Solver:
  • 10 Answers
It sounds like you have a small crack on your screen that has gotten worse over time, these black areas are where the lcd crystals aren't active anymore, unfortunately there isn't allot you can do apart from buy a new screen or put up with the black lines.
Posted on May 02, 2011
Anonymous
SOURCE:
Powermac screen developed fine black grid and won't operate properly
Isolate the problem to see if it's the screen or video card by connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok without a problem then your original screen is bad and your video card is good. If the Borrowed monitor displays the same problems as your original then your video card inside the computer is bad.
May 29, 2012 | Apple Powermac G4 Quicksilver Logic System...
Black line across the screen
I have the same problem. I have black smudges on my screen and they came out of nowhere. It wasn't that bad the 1st day I noticed it but I had turned on my camera the next day it had gotten worse. I have the samsung SL600 12.2 mega pixel..
Aug 16, 2010 | Samsung SL600 Digital Camera
Vertical lines across screen on my panasonic tv PT-61LCX65
Try setting a portable fan aimed toward the cooling vents on the back of the set. If this eliminates or reduces the occurance of the lines, this means a circuit that controls the off/on of individual pixels has developed a thermal problem. This circuit is ordinarily loacted on the main circuit board and is likely to degrade further. You might inquire at the Panasonic service center if they have an exchange program in place and they will probably be able to confirm my suspicions.
Aug 09, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
My KDL46X3100 has developed two thin black lines
It is problem of LCD Panel that will be replaced.
Please check with dealer / store for extended warranty option.
Aug 07, 2009 | Sony Televison & Video
I have black spots on my monitor screen that seem to multiplying.
The black dot will just grow until the rest of the screen fades.
It is pixels dieing in the monitor
Jul 22, 2009 | Computers & Internet
Black spot
If the black spot is always on the same location then you have to clean your lens, if it changes location, bring it to the service center for firmware reload.
I hope this helps.
Jun 13, 2009 | Cameras
Black horizontal line across the middle of the plasma TV screen
It could be a defective Y-Buffer board, or a defective Plasma panel.
Oct 25, 2017 | Pioneer PDP-425CMX 42 in. Plasma...
Blue circles on images forehead, cheeks and chin.
Try cleaning the contacts on the connectors going into and out of the Tcon board, if that doesn't fix it replace the board, here is the manual if that helps.
Samsung HL S4266W Owner Instructions Manual
Jan 06, 2018 | Televison & Video
Black line running horizontally across TV screen
A line on an LCD, either horizontal or vertical usually means the video driver board is defective or the screen is defective, does it show up as black even on a dark screen? That means a line of LCD "shutter"s is not working and there is a problem that cant be fixed by a reboot or channel change. Bummer.
Feb 17, 2008 | Televison & Video
Gateway FPD 1730 17" Flat Panel LCD Monitor Logo
153 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
