SOURCE: I need replace coffee pot
Try Walmart or one of the home stores first. If not...smallappliance.com
SOURCE: half a pot short of a good morning
Sounds like the thermal fuse (search this database under "fuse" and you'll find a discussion of it). I have yet to find the proper TORX security wrench, so I haven't been able to get to mine in order to try the things mentioned there, but I have a similar problem and what is said there makes sense.
SOURCE: FME2 Coffee Maker
From page 9 of the manual:
Setting and Adjusting the Clock
• The machine must be “off“.
• Press and hold the prog button (o) for 3 seconds: the hours will blink “88 _ _“.
• Adjust the hours in steps by pressing the h/min button (n).
• Press the prog button : the minutes will blink“ XX 88“.
• Adjust the minutes in steps by pressing the h/min button.
• Confirm the setting by pressing the prog button.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Manuals/ResultManuals.htm?SelectedService=Manuals&SelectedGuIDService={FA4AA2D9-9799-4F8F-8136-8FEB029407FD}&SelectedProdRef=FME2
SOURCE: weak coffee
Have you de-scaled and rinsed your Keurig?
Two things more you should look after: Boiling temperature and cleaning the funnel and exit needle.
Instructions here:
http://www.keurig.com/help/B60_Use&Care_guide_spreads.pdf
SOURCE: Leaks under pressure
Hi
Your brew head gasket is leaking and needs to be replaced. remove everything and turn the machine on its top. Look ate the brew head inside there is a black gasket and it should be clean and flat. If its cut or curled it needs to be replaced. Not cleaning the brew head will cause this gasket to be cut and after a while it will curl and not seal.
