It would seem this error code refers to you network protocols. Here is a sugestion from someone with the same problem on youtube. How to fix the 80710723 error on the PS3
Yes i always play my games without a connection to the internet and when i want to play against other persons thats when i connect it to the internet. I hope this helped you out!!
Your D-Link DI-24UP needs to "log into" your ISP's network again - by switching it to a new (DSL? cable?) modem, your router lost its "login" with the ISP. Solution: power cycle the router. This will force it to log back into your ISP's network, at which time you'll have to supply (probably manually), your account name and password that your account has with your ISP.
ya first apply the clock wallpaper then simply restatrt your phone .its now applied. if still the same problem update your phones software with the latest phone software upadate
It sounds like your using a router which seems to be interrupted or your internet is going out on you.
I
would highly suggest downloading the updates from your computer and
then use a USB drive to transfer the update to your PS3. It works
quicker for me :)
Here is the link where you can get the updates http://us.playstation.com/support/systemupdates/index.htm
Format a flash memory to FAT 32. go to playstation website, download the latest update version (under system) on a flash memory. arrange folders like this:
PS3-->UPDATE-->PS3UPDAT.PUP
hook the flash memory to the PS3 usb. go to system update--> use update from the other option rather than internet.
and you good to go!
You have a network/router error. First go to settings, then Network settings, then internet connection settings.
If you have a wired connection connection 1 - Custom, then manual settings, then auto detect, then automatic, then Do not set, then manual, DNS1 : 208.67.222.222 , DNS2 : 208.67.220.220, then auto, then do not use, then enable. If you are using a wireless connection 2 - WIRELESS > ENTER MANUALLY > ( ENTER SSID OR CONTINUE ) > ( CHOOSE SECURITY OR CONTINUE ) > CUSTOM > AUTO > DO NOT SET > MANUAL ( DNS1 : 208.67.222.222 , DNS2 : 208.67.220.220 ) > AUTO > DO NOT USE > ENABLE > X > X and if neither of these works then try turning off your modem for a few minutes and restarting your ps3 =)
download this rom and try installing....
http://bit.ly/aFOu60
it's processor doesn't support wm 6.5 and above...so stick to 6.1...
also check this...
http://bit.ly/avgdk7
