Cell Phones Logo
Posted on May 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need a puk pin code - Samsung Cell Phones
Anonymous
Level 2:
Scholar:
  • Expert 76 Answers
  • Posted on May 01, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
76
Questions
0
Helped
16938
Points
268
The PUK code is not related to the handset.
It is rather associated with your SIM card.
When you enable the PIN in your SIM card, every time you switch on your phone, you will be asked for your pin. At given number of tries provided by your mobile operator, that you have provided the wrong PIN (usually operators set it at 3 tries), then you came to the stage called PUK-blocked.
To unlock, you would need the PUK code of the SIM card. The PUK code is usually an 8-digit code. This PUK code should have been provided to you when you purchased your SIM card. Some has the PIN-PUK code printed in the card body of the SIM card, while some attach it as a separate print out. If your operator failed to provide this PIN-PUK code to you, perhaps, you would have to get it from your operator. Try calling your customer service. Just like the PIN, the operator as well could say how much tries do you have to successfully unblock the PUK of your SIM .
Anonymous
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on May 17, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
Helped
2733
Points
31
Get the PUK Code from service care...
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on May 16, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
1993
Points
20
Get the PUK Code from service provider.....
Anonymous
Level 1:
New Friend:
  • Contributor 15 Answers
  • Posted on May 05, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
15
Questions
0
Helped
1703
Points
22
You can get the PUK code from service provider.
1helpful
2answers
These are my numbers 0796086761 and i need mt PUK please
Make the FixYa experience better for everyone by voting.
My name is Ben and I'm your guru, i.e., mentor, an influential teacher or popular expert: a management guru. - origin from Sanskrit, 'weighty, grave' for today.
Subject: How to unlock a SIM card
Customer's exact description: these are my numbers 0796086761 and i need mt PUK please
Discussion: Problems of this type can be easily solved. Customer did not provide the name of the service provider.
Solution: Provide instructions for unlocking a SIM card
PUK Codes
A PUK (PIN Unlock Key) code is required to unlock SIM cards that have become locked following three successive incorrect PIN entries. If your SIM card becomes locked, you will need to get a PUK code from AT&T to unlock your SIM card.
Since I don't know the name of you carrier, I'm using AT&T as an example. Most carriers use the same methodology though the wording may be different.
You can obtain your phone's PUK code from AT&T in one of these ways:
Take the phone into your carrier's retail outlet.
OR
• Log in to myAT&T online
• Use our Technical Support Chat.
• Contact Customer Care
To get your phone's PUK code online:
? Log in to myAT&T.
? From the myAT&T tab at the top of the page, hover over the Wireless link and select Phone/Device under the My Wireless Service heading.
? From the My Phone/Device screen, select the Unblock SIM Card link under the My Make & Model heading.
? The Unblock SIM screen will display your PUK code and will give you instructions for unblocking your SIM Card.
Once you receive your PUK code, you will need to enter it into your phone to set a new PIN code.
Note: If you enter the wrong PUK code 10 times in a row, your SIM card will be invalidated, and you will need to purchase a new SIM Card. The phone will display the following error: "PUK blocked call operator."
Second Solution:
You can also do it without any assistance from anyone. However, be sure to read the following carefully because there are pitfalls. If you want to try to do it yourself, just click on the following link: Universal Software Solution for Unlocking a SIM Card
Although most people remember their primary SIM PIN code, those other codes - used for various verification purposes - are never to be found when needed. Below I've included a set of short codes which, when entered on a handset's standby screen, will let you easily change PIN and PUK (short for Pin Unlock Code) codes - but keep in mind, they may not work with all handsets and mobile operators.
More importantly, when changing one's PUK codes there'll be no help to get from the mobile operator if the new codes are forgotten, so make sure to write any changes down alongside the old PUK codes.
The Final Solution:
The following methodology does not work for every phone. Perhaps you'll be lucky. Also, please note that the codes should be entered without the spaces shown below.
Change SIM Card PIN
** 04 * old PIN * new PIN * new PIN #
Change SIM Card PIN 2 (Write down the new code)
** 042 * old PIN * new PIN * new PIN #
Change SIM Card PUK (Write down the new code)
** 05 * old PUK * new PUK * new PUK #
Change SIM Card PUK 2 (Write down the new code)
** 052 * old PUK * new PUK * new PUK #
Display Handset IMEI
*# 06 #
This was wordy but hopefully it helped you.
Ben
*# 06 #
Ben
Sep 11, 2011 • Cell Phones
SAMSUNG S5233 WHY THEMES IS NOT DOWNLAOD ?
Tired of memorizing new PIN codes? We show you how to change your SIM card's various PIN and PUK codes in less than 5 seconds.
Although most people remember their primary SIM PIN code, those other codes - used for various verification purposes - are never to be found when needed. Below we've included a set of short codes which, when entered on a handset's standby screen, will let you easily change PIN and PUK (short for Pin Unlock Code) codes - but keep in mind, they may not work with all handsets and mobile operators.
More importantly, when changing ones PUK codes there'll be no help to get from the mobile operator if the new codes are forgotten, so make sure to write any changes down alongside the old PUK codes. Also, please note that the codes should be entered without the spaces shown below.
Change SIM Card PIN
*# 06 #
<a href="http://www.5starandroid.com">Android Mobile</a>
My samsung B7722, first time insert sim card, after enter pin number, error massage came out "phone freeze, sim unavailable, please contact your service provider" how to settle?
Although most people remember their primary SIM PIN code, those othercodes - used for various verification purposes - are never to be foundwhen needed. Below we've included a set of short codes which, whenentered on a handset's standby screen, will let you easily change PINand PUK (short for Pin Unlock Code) codes - but keep in mind, they maynot work with all handsets and mobile operators.
More importantly, when changing ones PUK codesthere'll be no help to get from the mobile operator if the new codesare forgotten, so make sure to write any changes down alongside the oldPUK codes. Also, please note that the codes should be entered withoutthe spaces shown below.
Change SIM Card PIN
*# 06 #
23helpful
9answers
Jazz pin and puk code
My dear:
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
But:
Don't try to enter a PUK code without knowing the right one.
You need to call your service provider to get this code.
It can be as many as 8 digits, and it is random. If you enter too many wrong codes,
you can permanently damage the device. So Please You Go to Service office
and Get the Duplicate Sim From Office Oprater Same Your No Problem will Solved
Aug 31, 2010 • Cell Phones
3helpful
2answers
Pin blocked and need puk code
If you enter the wrong password three times in a row the SIM card gets blocked. This is indicated by the message PIN Blocked To unblock this you need to enter your PUK
code (Personal Unblocking Key). Your PIN and PUK is supplied by your service provider. so contact your service provider
Sep 01, 2009 • Cell Phones
1helpful
I have an lg vu and i wanted to see what happens after the pin is gone 5 times now my screen just sayz puk blocked please need help!!!!!
If all else fails, you can use cellunlockstore.com for $1.99. Try the instructions below.
To change your SIM card's various PIN and PUK codes:
Change SIM Card PIN
Jul 19, 2009 • Cell Phones
2helpful
Yh need me puk number
What is a PUK code? A PUK code (Pin Unlock Key) is required when you enter an incorrect PIN 3 times. After entering the wrong PIN 3 times, the card will be locked and you will need to get a PUK code from your phone company to unlock it.
What should I do if my phone says Enter PUK Code? How can I get a PUK Code? You can receive your phone's PUK code by calling your phone company Customer Care.. Once your PUK has been received, it will need to be entered into your phone to set a new PIN code. If the wrong PUK code is entered ten times in a row, the SIM card becomes invalid and you will need to purchase a new SIM Card. The phone will display "PUK blocked call operator".
12helpful
9answers
NEED PUK CODE
i have locked my phone but dont know my puk or pin
4helpful
3answers
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
