Hi yasein, what version of windows is on your pc?
download these two files and extract both
this one is the spl installer which needs to be run on your computer, if you get an error you will need to use the next download on the phone first
http://www.mediafire.com/download.php?sspbx0b1o3dqmtl
this next one needs to be extracted and then copied to your phone and then opened on the phone itself to be installed
http://www.mediafire.com/download.php?dvubl37qzaw2mh0
Please make sure Activesync is enabled (green icon in systray)
and hit ENTER to start...
STEP 1/3......50.......75.....100.
The next step will load a patched bootloader (SPL) on your device
it will make your device temporary SuperCID (seclevel=0), and will
avoid modelID and signature checking when flashing NBH files.
Hit ENTER to continue...
STEP 2/3.....15......25....50....75......100.
Phone screen should now be blank and the activesync icon gray
if not, the loading procedure has failed and you'll have to repeat again.
If all was OK hit ENTER and the standard "PDA Phone ROM Update Utility"
window will start, allowing you to flash patched SPL on your device.
Hit CTRL+C to Cancel or ENTER to continue...
Follow the steps on the wizard to flash the patched SPL, when this
step completes your device will reboot.
STEP 3/3 - Launching RUU, please wait...
Process is finished, congratulations!
If you find it useful don't forget to donate :)
(c)2007 pof - XDA Developers
Hit ENTER to quit.
Hit ENTER to quit.
then follow these instructions
STEP 1/3......50......75....100
STEP 2/3.....15......25....50...75.....100
Hit ENTER to quit.
if you have had success with installing the first file and it has completed without error then you can now download this file
http://andrewloh.com/HTC/New_Blue_Touch_ROM_V4.0.zip
extract all files in it and run the ruu_setup file in there and follow
th instructions on screen. When its finished you will have wm6.1 in
english installed on your phone
