SOURCE: Stoves 720EF Top Oven Failed
there is a safety stat/fuse on top of the oven exterior i think you will find that it also has blown. Make sure you have isolated the appliance at the fuse board first though, Good Luck
SOURCE: i have no instructions for my stoves envoy cooker,
You can ring stoves on 08712222502 they will usually email over a manual for free you just need your model and serial number of your oven.
This can be found usually just behind the door to the grill.
hope this helps :)
SOURCE: Smoke comes out of grill on electric cooker
hi, what you will probably find is that the grill over time has got grease on it and other contaminents from food you have cooked in the past the best thing to do is turn the grill on full and let the smoke burn out open windows etc as it will stink the whole place out it may take a while to get hot but just wait leave it on full and you should find it will burn off all the grease etc and then it will stop smoking.
If you turn it on full and then you get nothing happen after about 10min then turn it off and you would then need to think about getting the element replaced.
Let me know how you get on or if you need further assistance ok
SOURCE: Sorry, I don`t speak english. I have two p...
the p0301 and is the same as the p0302 could be wires or plugs if u did that take the neg cable off for 20 mins u might have to do that a few times
SOURCE: I have a Creda Carefree
Does it make any difference on the length of time it stays compared to where you have the thermostat temperature set. If it doesn't, the thermostat may be bad. If you know what you're doing you can bypass the thermostat to see if it stays on.
