SOURCE: Error 22
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
SOURCE: canon PIXMA MP210 printer all-in-one
Go to this cannon link & type in the search windows error e2 than click search. If nothing helps or fix's the printer call Cannon.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15402
Canon support:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2110&fcategoryid=238&modelid=15402
Mike
SOURCE: error code 6502 on MP510
Canon help desk told to unplug the printer for at least 15 minutes. The electronics will reset. If the error persists after turning the printer back on you're screwed and have to send it to Canon, because some electronic component is broken.
SOURCE: Installed new cartridge in canon pixma mp210 & now can't print
The printer needed to be reset.
Unhook the printer then take out the new cartridges.
try to very gently clean the contacts also make sure the contact on the new cartridges is clean.
Let it dry for a few minutes assembly.
Plug it. My printer is reset by pressing the start button and hold it down until it beeps 6 times.
You can check your manual how to reset yours.
I hope it work for you.
