116-324 System Controller RAP An exceptional Controller error shut down the processor. Initial Actions Power Off/On Pull out and insert or replace the DIMM (PL 11.2). If the problem persists, replace the ESS PWB (PL 11.2). The ESS fan failed.
Procedure
116-325 ESS Fan RAP
Procedure
Replace the ESS fan (PL 11.2).
1. Turn machine off at machine switch (not the power point)
2. Disconnect machine's internet cable (looks a bit like a phone line cable)
3. Before turning machine back on, press and hold the Stop and Start buttons together at the same time (red and green?).
Keep holding them down together whilst you turn the machine back on.
4. Wait for machine to start up and normal display screen to show.
5. Then you can let go of the buttons.
6. Re-connect cable.
All done!
Yeeaahh fix it, thank you
2. Disconnect machine's internet cable (looks like a phone line cable)
3. Before turning machine back on, press and hold the Stop and Start buttons at the same time (red and green?) - Keep holding them down together whilst you turn the machine back on.
All done!
It worked,Thanks!
I just tried this after spending several hours puzzling what to do with this 116-324 errro and it worked perfectly, thanks for your Help! Fixya!
it's worked. my root cause, code 116-324 show when there is 1 file can not be cancel job status.
