Question about JBL On Stage II with Remote Remote Control for iPod and MP3 Players, Black (086792279251)
What battery goes into rf remote control for JBL onstage micro III
    New Friend:
CR2025
Posted on Jun 11, 2013
3 Suggested Answers
6ya staff
SOURCE:
Aloke Das
  • 1833 Answers
SOURCE: Volume up button will not
HI,
This is not a big problem, even operating from remote controller is better. It makes long lasting to your hardware. But you should repair the volume button. There is the problem of circuit or the button. Change the button with a new compatible button. You can purchase button from nearest JBL service centre or JBL accessories shop. If it doesn't solve your problem then you have to repair the circuit.
Posted on Jun 14, 2011
Anonymous
SOURCE: i need to open a JBL onstage II speaker system to
you have to remove the 3 sticky pads in at the bottom of the speaker and there you will expose all the screws that need to be removed...there is also one where the batteries go
if you have any luck replacing the ipod dock let me know please
Posted on Nov 15, 2009
The sound is screeching when the volume is louder
that screeching is called feedback..which is caused by loop oscillation in plain english that means that sound is going from the speaker to the microphone and "looping" causing feedback noise or "screetching" there is nothing you can do but lower the volume it's a normal phenom not a fault in the product but more user error. sorry to say. the only thing you can do is lower the volume till it goes away.
Dec 12, 2013 | JBL On Stage Micro Speaker Dock for Apple...
Unit turns on but there is no volume
Check its speaker first. If it is found OK, check and replace audio output board as card basis. Visit the site named 'Electro-help' for more details. Click this link. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 900 posts to different brand TVs now.
Oct 02, 2012 | JBL Onstage Micro Iii Portable Speaker...
I am thinking of getting and Ipod touch 3G. I have JBL on stage micro Speakers. I've charged a Ipod touch 2G, but I want a 3G! Please Help!
When the OnStage speakers first came out, the charger was not compatible with 3g iPods or iPhones. Newer speakers have an upgraded charger and will charge all current iPods/iPhones (up to and including iPhone 3Gs)
Bad news is that there's no way to upgrade an old OnStage.
You can test yours by trying an iPhone 3G (if you have a friend with one, for example) to see if you have the old or the new charging circuit.
Jan 23, 2010 | JBL On Stage Micro Speaker Dock for Apple...
I need to open a JBL onstage II speaker system to reattach the ipod dock, i can do that, it just doesn't seem to open
Oct 17, 2009 | JBL ONSTAGE Docking Station for iPod
JBL on stage micro will not charge my ipod any more. It plays songs fine from the ipod but for some reason is not charging it. Any suggestions?
The JBL Onstage Micro is supposed to disable recharging of the iPod when running off AAA batteries to avoid draining them, but sometimes this setting gets stuck even when the unit is plugged in through the AC adaptor. The workaround that I found is pulling out and reconnecting the iPod to the Onstage Micro (while both are powered on) and then unplugging and reconnecting the AC adaptor. Sometimes you have to repeat this process, but the iPod should start recharging after that. I tried it on the new 5th generation nano and this seems to work.
Jun 14, 2009 | JBL On Stage Micro Portable Speaker Dock...
When plugged in, the ipod batteries go low immediately.
The JBL On Stage Micro is supposed to disable recharging of the iPod when running off AAA batteries to avoid draining them, but sometimes this setting gets stuck even when the unit is plugged in through the AC adapter. The workaround that I found is pulling out and reconnecting the iPod to the Onstage Micro (while both are powered on) and then unplugging and reconnecting the AC adapter. Sometimes you have to repeat this process, but the iPod should start recharging after that. I tried this on different versions of the iPod nano and this seems to work.
Apr 16, 2009 | JBL On Stage Micro Portable Speaker Dock...
JBL onstage speakers have no volume
where did you buy it from? I got a few solutions. Email me at jyeah1212@yahoo.com.
Jan 15, 2009 | JBL On Stage II with Remote Remote Control...
Will not charge a ipod touch 2
If you're willing to spend $40, there's an adapter available from Scosche Accessories. It comes in both black and white and they say it will convert any docking device to the new charging format. (The problem is that Apple has discontinued charging via the FireWire pin - which virtually all accessories - even including Bose - have used up to now. All the 2nd Generation stuff now uses direct USB charging, not FireWire.
Check out the convertor at:
http://scosche.com/products/sfID1/210/sfID2/339/sfID3/318/productID/1694
Dave
Dec 29, 2008 | JBL On Stage II with Remote Remote Control...
JBL On Stage II with Remote Remote Control for iPod and MP3 Players, Black (086792279251) Logo
260 people viewed this question
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
