This error LLL on the display screen is as a result that the temparature controller is faulty or the the temparature probe is kaput
I do face the same indication but checked the temperature probe already with a lighter and the resistance changes so i would say that is functioning,i just fitted a :Lincoln Thermostat Control Board PN# 369728 w/ 40° - 560° Range 4030118
Is that a possibility that is a faulty one?
do i need to replace the temp probe anyway?
pls advice me
SOURCE: oven not reaching correct temp
It isn't a design flaw. It is an air pressure switch. Main fan not running OR oven is dirty and the tube to the air pressure switch is clogged. Dirty ovens aren't a design flaw. I saw it once a week. Five minutes clearing the tube and you back in business. Hope this helps.
SOURCE: I got a 1301 208v the fan blows good but it does
If threre is no alarm please make sure that the gas inlet pressure is ok or contact me at [email protected]
SOURCE: Hi, my daughter has an impinger lincoln pizza
First you should check the ac source of the unit if their is a power try to use some device to confirm that there is an ac supply like charger or electric fan, if there is power to the source then you should check the fuse if not busted or if it using a breaker try to turn it of then turn it on it may be defective sometimes the contact of the breaker is not properly contacting to each other this hopping that this may help you. thank's
