Computers & Internet Logo
Posted on Apr 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am using ubuntu 10.04.2 and epson lx 300+ printer. When i try to install i am not able to select device as parallel port #1. What should I do?
Anonymous
Level 3:
  • Master 591 Answers
  • Posted on Apr 29, 2011
Anonymous
Master
Level 3:
Answers
591
Questions
Helped
172696
Points
2033
I don't know I've used Ubuntu for years and I've never had to configure a printer in my life, it allways managed to install it self...
Is your computer connected to the internet when Ubuntu install the driver???
Have you tried an other printer cable??? have you tried the printer in an other computer???
1helpful
How to change from serial communication to parllel com mode
OS settings to change port ---------------------------------------Click Settings > Control Panel > Printers and Faxes > Select your installed printer and right click on it > select properties > Ports > change serial port to parallel (COMx to LPTx)
Printer Settings to change port-------------------------------------------------Click here for EPSON user manual and refer page number 36 for printer settings. Change I/F mode to parallel (Interface mode) as instructed by Epson.
I have epson lx 300+ printer and bought a new cpu without any parallel port... now my printer does not print documents even a successful printer driver installation
You can install a parallel port adapter on you computer.
This WEB site has parallel port adapters that suit your computer.
http://www.ieci.com.au/products/product_list.asp?class=3&basecat1=50
Since you did not provide details of your computer I cannot advise you exactly what adapter you need, but you can select or ask the supplier the correct one for your computer.
2helpful
Can not print with Epson LX-300
The USB to parallel converter does not always work.
You should buy a Parallel port for your computer if you have can extra slot inside the machine. The cost for the parallel port is usually under $20.
thanks adi
1helpful
My epson LX 300+ was already installed but will
First, you must install the driver of lx-300+. open control panel, printer n fax then find epson lx 300+. Don't forget to test what port that your lx-300+ support. LPT1. Then print test page...If your printer run... it's finish... you have succses instal the printer...
4helpful
How do i install an epson lx 300 printer to a vista machine using a parallel to usb converter? i can't locate nor create usb 001 port with the driver cd of the said printer.
1. Start
2. Settings
3. Printer and Faxes
4. Add a printer
5. then Next
6. then Next
7. then Next
8. then Next
9. select Manufacturer name : Epson
10. select Printer name : Epson LX-300
11. Next
12. Windows will automatically install the driver for your Printer
XP Cannot able to print on Epson LX 300+
This is XP's parallel port problem
try changing the settings:
find: Start Button, Control panel, System
Device Manager, then Ports !
Change the settings for LPT1 to enable
Detection of Legacy Plug and Play devices
o and Here is the service manual for this printer:
http://ca.geocities.com/artiedc/LX300SvcMan.pdf
Ed
I WANT MY EPSON LX-300+ INSTTALE TO MY COMPUTER
This printer needs a parallel port only. And if youre using xp os just make add printer and it will just add this printer, driver is almost ready. If it ask for driver just insert the winxp installer cd.
hope this helps
16helpful
5answers
Epson LX-300 can't print
Check your parallel port settings on the XP computer. Compare these setting with the settings on the computer where the printer works. If you are using serial port for printing, then check the serial port settings.
Grand Canyon Tech
Grand Canyon Tech
