My philips 27" tv has the caption continually on. I want to turn it off. Is there a way to turn it off with the four buttons on the tv? I have the same issue with a Sanyo model thought that when I got cable I could remove it with the cable remote can't does not display the menu for CC.?????? What's a know-it-all to do?. I have a UR. Don't know the Model #
The following should solve your problem if you have a comcast digital cable box and possibly for others.
Hey, it's worth a shot!
Turn the TV Power on and cable box power off.
Press the MENU button on the front of the cable box.
Scroll down to the caption item on the menu and toggle it to "disabled"
Press the menu button again to close.
Hope this helps!
Thank you D little !! Change your name to D Big Man !!
SOURCE: Closed Caption won't turn off
Nope your gonnas need to get a remote that operates the menu. Theres an original thats available from 1800 remotes or http://www.remotes.com for 50 bucks. Thats like 25 less then the one from phillips! Goord Luck
1.Press the CC button on the remote to display the current Closed Caption setting.
2.Press the CC button repeatedly to choose from the four Closed Caption options (CC
Off, CC1, CC2, CC Mute). select CC off.
3.When finished, press the STATUS /EXIT button to remove the menu from the TV
i have the same problem. the cc wont turn off the tv and my universal remote doesnt do anything
D Little was 100% correct. My cable company said (seven different peoople) it was MY TV. IT WAS THEIR box that had the problem.
Thank you sooooooo much D Little.
