Lenovo G550 Notebook Logo
Posted on Apr 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can i remove the battery of my loptop and directly plug it to an outlet wen i using my loptop for long period of time
Anonymous
Level 3:
Genius:
  • Master 1,542 Answers
  • Posted on Apr 28, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1542
Questions
5
Helped
287278
Points
4659
Hi
Yes you can do this in fact if you constantly use the electric plug it is wise to remove the battery
as this will extend the battery life
2helpful
Remove batteries first?
The short answer is yes, but if the batteries are left in for long periods of time without being used they may leak.
tip
Should I Remove the Laptop Battery?
Question: Should I Remove the Laptop Battery?
I have a dell latitude d820 laptop at home which I use as a desktop replacement. As such, 99% of the time the laptop is being used it is plugged in. I wonder if I should remove the dell latitude d820 battery so that it is not permanently being charged, or does the laptop cut off the current to the battery once it is fully charged? I do unplug the laptop when I turn it off.
Answer: When using a laptop as a desktop replacement the battery should not be left in for long periods of time. The laptop will over time discharge the battery. Remove the battery – making sure that it is charged to 40% and store it in a dry, warm place. Ensure that it is wrapped protectively and nothing will be dropped on it.
The battery should be re-installed every 3-4 weeks and allowed to fully discharge. Leaving a battery in storage for longer than this without using could cause the battery to fully discharge as the circuitry of the battery itself consumes power.
Leaving a battery in a laptop while using an electrical outlet for long periods of time will keep the battery in a constant state of charging up and that will reduce the life cycle of the battery.
Remember that when you have removed the dell vostro 1500 battery from a laptop while using with an electrical outlet – the automatic battery backup is no longer functional. Make sure to plug your laptop into an uninterrupted power source (UPS) not directly into an outlet or surge protector.
on Apr 20, 2010 • Computers & Internet
Can i remove the battery of my loptop and directly directly plug it to an outlet
Of cource not, Cause you electric shock yoursefl or broke your battery. Rate my Solution Please. Thanks.
Battery doesn't appear to be charging.
There may be several physical problems. You should make sure that the battery is properly plugged in and no switches that allow it to be removed are in the open position. Checking that the power cord if plugged in proper at the laptop, the power brick, and the power outlet may also solve the problem. If none of these work, try using a different power cord that fits your laptop if you can get your hands on one. You may also want to try a different power outlet, or make sure that power outlet can power another device (eg vacuum, phone) so you know if it's actually a problem with that power outlet and not your computer.
If you battery doesn't charge even with a cable that you know works for another computer, and the outlet is working properly, your battery may be corroded or suffering from over-use over a long period of time. In this case it would be best to buy a replacement battery directly from Dell which you can do here:
http://www.amazon.com/Replacement-Laptop-Battery-Studio-7200mAh/sim/B003FZ33SS/2
2answers
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
TV will not power up, no lights blinking just a continuous beeping sound
Please follow the below troubleshooting steps: 1. If the Television is plugged into a surge protector, remove it from the surge protector and plug it directly into the wall outlet. 2. Try connecting the TV to a different AC wall outlet. 3. Try power resetting the TV. To Reset the TV, disconnect the power cord for a short period of time (approximately 1 minute), then reconnect the power cord and power ON the TV. 4. If the issue still persists, TV will require service.
2helpful
Hi, The battery light on my Inspiron 6000 flashes 3 times red and then green repeatedly. What does this mean? Also, after the computer is plugged into an outlet for an extended period of time the power...
the battery has reached its expected life, you need to replace it. If it is under warranty, you can call dell and have them replace it. You can still use you laptop with the wall power/charger plugged in, remove the battery to get rid of the flashing red/green light.
ELECTRICAL POWER DOES NOT SEEM TO WORK EVEN THOUGH PLUGGED IN
Try another outlet in your home. Or if it is plugged into a surge protector remove it for the surge and plug it directly into another outlet
PSP
Try removing the battery and reinserting it, if you are plugged to an outlet directly try using a different charger it might have burnt out as this commonly happens when we leave the cable plugged to the wall for long periods of time and also if the unit was plugged for a long time the battery might have burnt. the solution wold be to verify that the battery and the charger are working properly, try that and good luck!
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
