https://support.hp.com > ca-en > document
When a 30.03.23 Error Alignment Calibration Failure appears on the control panel, it indicates there is an issue calibrating the scanner.
The "Scanner Failure" message appears when the scanner unit doesn't responds to the commands from the printer's processor. This is a major hardware failure - the scanner unit is effectively dead.
Replacing the failed scanner unit with a new one would cost more than a new All-in-One so either use the printer as is (just as a simple printer) or sell it for parts and get a new one.
Remove power and leave out for 30 seconds. Hold cancel and left arrow and reinsert the power. Attempt to copy, if it still does not work you may need to have the unit serviced. Technical support can set-up an exchange if in/out of warranty, if out... it will be more that $100 for another unit. You can try to call some local providers for a quote on prices as they vary from ASP.
