Husqvarna Chain Saw 20" Bar Logo
Posted on Apr 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you set the chain tension on a 345e? - Husqvarna Chain Saw 20" Bar
Andrew White
Level 3:
  • Husqvarna Master 2,239 Answers
  • Posted on Apr 28, 2011
Andrew White
Husqvarna Master
Level 3:
Answers
2239
Questions
Helped
910721
Points
5950
The E version is tooless, so flip out the wing in the centre of the big cover fixing nut,slacken the nut off half a turn, now turn the knurled adjuster in the side cover, down to tighten, up to slacken, there are many schools of thought about the correct tention of the chain, but basically the chain should sit snuggly all round the guide bar, and with a gloved hand pull manually around the bar with out too much force, it should never sag on the bottom of the guide bar.
Torque settings for the timing chain single row ????
VWVortex.com - DIY - Replacing timing chains, tensioners and ...
forums.vwvortex.com/showthread.php?...timing-chains-tensioners...guid...
Feb 29, 2004 - 25 posts - ‎13 authors
The timing chain setup on a VR6 consists of an upper and lower chain. ... with an "improved" setup consisting of a single-row chain, a single-piece, ... (Note: Torque specs given in this DIY are from the MKIV Bentley manual ...
How to: Timing chain replacement on KA24E - Infamous Nissan ...
www.infamousnissan.com > ... > Tech Area > Engine and Drivetrain
Dec 9, 2011 - 10 posts - ‎4 authors
Description: Timing Chain (single row, 102 links) ... Dealer, $59.14 CourtesyParts.com. Description: Tensioner Guide Bolts (slack side bolt)
Replacing a timing Chain, guides, tensioner and sprockets ...
bmwmotorcycletech.info/timingchain.htm
The LEFT photo is of the 1979 and later SIMPLEX chain (one row of chain rollers). ...and this means the engine will not develop its designed torque and power curve. The ignition timing gets sloppy from, firstly, the chain guide/tensioner initial ...
How do i adjust the chain that lifts the door
Take the chain off the gear. Run the opener limit to the bottom (closed) limit. put the chain back on the gear. Loosen the set nut on the chain. Tighten the tension nut on the chain to desired tension. tighten the set nut on the chain.
Change chain
Loosen and remove bar lock nuts and cover. screw tensioning screw to loosest point. wrap chain onto teeth of drive sprocket, then within grooves on bar. Be certain cutting edges are facing forward. Look at chain before removing. set bar with new chain to ensure the tension pin aligns with bar tensioning hole. Replace cover set nuts loosely. Tighten chain to about 1/4" out of groove when pulled on (wear gloves). Tighten nuts, spin chain to see it moves freely but does not hang free og bar groove. re-tension as necessary. Happy cutting!
Cam chain adjustment
cam chain tension will not cause your problem. A miss at revs is electrical (coil -points-ht leads-plugs etc) and possible air/ fuel ratio problem --leaning out at revs from jet size setting
3helpful
I am trying to determine if the adjustment bolt located below the carbs between the second and third cylinders is for setting the cam chain tension and how to set it . There is some cam chain noise at low...
Yes, it is the cam chain tensioner. With the engine off, just loosen the tensioner lock bolt then strongly tap a few times on the tensioner casing with a screwdriver handle. This will free up the spring loaded tensioner. Now just re=tighten the tensioner lock bolt and you're done. Please rate my answer. Thanks. tombones49_157.gif
1helpful
I need to know how to set thte timing chain
Discoverd this indepth expalaination of process steps involved in the installation of the timing chain from an ASE certified technician. I hope this helps. See the repair manual on the link below.<br /> <br /> Link: <a href="http://www.2carpros.com/forum/2002-jaguar-xj8--gearbox-default-appear-on-dashboard/2000-jaguar-xj8-timing-chain-replacement-vt218070.html">http://www.2carpros.com/forum/2002-jaguar-xj8--gearbox-default-appear-on-dashboard/2000-jaguar-xj8-timing-chain-replacement-vt218070.html</a><br /> <table id="table14" style="BORDER-RIGHT: #000000 1px dashed; BORDER-TOP: #000000 1px dashed; BORDER-LEFT: #000000 1px dashed; BORDER-BOTTOM: #000000 1px dashed" bordercolordark="#000000" width="100%" bordercolorlight="#000000" border="0"> <tbody> <tr> <td style="BORDER-TOP-WIDTH: 1px" width="700"></td></tr> <tr> <td style="BORDER-TOP-WIDTH: 1px" width="700"><span class="name" roundtrip="0" lastvisited="3">By <a name="755408"></a><b roundtrip="0" lastvisited="0">Dave H</b>,<b> </b></span><span class="postdetails" roundtrip="0" lastvisited="0">Certified ASE Technician</span></td></tr> <tr> <td style="BORDER-TOP-WIDTH: 1px" width="100%" roundtrip="0" lastvisited="6"></td></tr> <tr> <td style="BORDER-TOP-WIDTH: 1px" width="700"></td></tr> <tr> <td style="BORDER-LEFT-WIDTH: 1px; BORDER-BOTTOM-WIDTH: 1px; BORDER-RIGHT-WIDTH: 1px"> </td> </tr> <tr> <td colspan="2"> <span class="postbody" roundtrip="0" lastvisited="77">PRIMARY TIMING CHAINS (NON-SUPERCHARGED) <br />NOTE:The 4.0L V8 has no engine timing alignment marks on the crankshaft or camshafts. Engine timing is achieved by installing the Crankshaft Setting Peg (303-531) and Camshaft Locking Tool (303-530). With the crankshaft setting peg in position, ensure the timing flat on each camshaft is in the uppermost position before installing camshaft locking tool. Variable camshaft timing unit may also be referred to as Variable Valve Timing (VVT) unit. <br /><br />NOTE:Special Tools Required: Crankshaft Setting Peg (303-531), Camshaft Locking Tool (303-530), Chain Tensioning Tool (303-532), Primary Chain Wedge (303-533) and Variable Camshaft Timing Oil Control Unit Setting Tool (303-654). See Fig. 232-Fig. 236 . <br /><br />NOTE:"A" bank refers to the right/passenger side of the vehicle and "B" bank refers to left/driver side of the vehicle. <br /><br />NOTE:Each door glass automatically drops 12 mm when the door is opened or when the convertible top is raised or lowered. It is important that windows are lowered before battery is disconnected to allow doors to shut properly. <br /><br />Removal ("A" Bank) <br />Tips Click a link to view tip <br />Tech1Tip: special tool <br /><br /><br />Remove timing cover. See TIMING CHAIN COVER (NON-SUPERCHARGED). <br />Remove the variable camshaft timing oil control solenoid. </span><br /> <span class="postbody" roundtrip="0" lastvisited="77">Remove the variable camshaft timing oil control unit housing retaining bolts and remove the variable camshaft timing oil control unit housing. </span><br /> <span class="postbody" roundtrip="0" lastvisited="77">Remove and discard the variable camshaft timing oil control unit housing "O" rings. <br />Raise and support vehicle. Remove the bolt which secures the Crankshaft Position (CKP) sensor to the flywheel housing. Remove the CKP sensor and allow it to hang free under the engine. Remove the torque converter bolts access grommet from the flywheel housing. </span><br /> <span class="postbody" roundtrip="0" lastvisited="77">Install the crankshaft damper bolt (old one) to the crankshaft, hand-tight only. Rotate crankshaft until the triangular arrow indent on the flywheel is visible through the access hole. See Fig. 144. Confirm that the timing flat on each camshaft is uppermost position. <br />Position the crankshaft so that the Crankshaft Setting Peg (303-531) engages fully into the timing slot. Install and tighten the bolt to secure the crankshaft setting peg. See Fig. 145. Remove the crankshaft damper bolt from the crankshaft and lower the vehicle. <br />Install the Camshaft Locking Tool (303-530) to the "A" bank camshafts, aligning the shafts slightly as necessary. Loosen the bolt that secures the exhaust camshaft sprocket and the bolt that secures the variable camshaft timing oil control unit. See Fig. 146. Remove camshaft locking tool. <br />Remove the primary chain tensioner bolts, primary chain tensioner and tensioner backing plate. See Fig. 147. <br />Remove the primary timing chain tensioner pivot bolt and remove the primary timing chain tensioner blade. See Fig. 148. <br />Remove the bolt which secures the primary timing chain guide. Noting the position of the primary timing chain guide, remove the primary timing chain guide from the upper retaining pin. See Fig. 149. <br />Remove the primary timing chain from the variable camshaft timing oil control unit and from the crankshaft sprocket. Clean and inspect all components. <br />Installation <br />If "B" bank timing chain was removed, see INSTALLATION. If not, go to next step. <br />If previously removed, install the timing chain sprocket to the crankshaft. The teeth of the "A" bank and the "B" bank timing chain sprockets on the crankshaft must be out of phase with each other. If they are in phase after installing, remove the sprocket, turn it on its vertical axis and reinstall sprocket. See Fig. 150. <br />Install the chain tensioning tool to the exhaust camshaft sprocket. Reposition the sprocket (and the variable camshaft timing oil control unit) for the most advantageous position for use of the tool. See Fig. 151. Remove the tool. <br />Install the primary timing chain into position over the crankshaft sprocket and the variable camshaft timing oil control unit. There must be no slack on the drive side of the primary timing chain and the sprockets must not be rotated on the camshafts, or the tensioning tool may not fit. See Fig. 152. <br />Install the primary timing chain tensioner blade to the cylinder block. See Fig. 148. Install the pivot bolt and tighten specification. See TORQUE SPECIFICATIONS. <br />Push the primary timing chain tensioner piston into the tensioner body to provide clearance for installing the primary timing chain. Insert a thin rigid wire through the hole in the end of the tensioner piston to displace the ball from the non-return valve seat. See Fig. 153. With the wire in position, press the piston fully into the tensioner body. Remove the wire. <br />Install the 2 primary timing chain tensioner bolts to the primary timing chain tensioner and locate the tensioner backing-plate on to the 2 bolts. Align and install the primary timing chain tensioner to the cylinder block and to the mating slot on the rear face of the primary timing chain tensioner blade. See Fig. 147. Tighten the primary timing chain tensioner bolts to specification. See TORQUE SPECIFICATIONS. <br />Use a Primary Chain Wedge (303-533), or 2 if needed, between the primary timing chain tensioner and primary timing chain tensioner blade, to take up the slack in the chain for tightening of the variable camshaft timing control unit and exhaust camshaft sprocket. See Fig. 154. <br />Using the chain tensioning tool, apply force to the tool in an counterclockwise direction to tension the chain on its drive side. See Fig. 151. While applying opposing force to the sprocket and chain, tighten the exhaust camshaft sprocket bolt to specification. See TORQUE SPECIFICATIONS. <br />Using the Variable Camshaft Timing Oil Control Unit Setting Tool (303-654), rotate the variable camshaft timing oil control unit fully counterclockwise to the fully retarded position. See Fig. 155. <br />Check that the primary chain wedges are still in place. While applying opposing force to the sprocket and chain using the chain tensioning tool, tighten the variable camshaft timing oil control unit bolt to specification. See TORQUE SPECIFICATIONS. Remove the chain tensioning tool and the primary chain wedges and camshaft locking tool. <br />Raise and support vehicle. Remove crankshaft setting peg. Install the CKP sensor and bolt to the flywheel housing. See Fig. 143. Tighten the CKP sensor bolt to specification. See TORQUE SPECIFICATIONS. Install the access grommet to the housing and lower the vehicle. <br />WARNING:Check that the ring dowels are engaged squarely. Fully locate the assembly as much as possible by hand. Failure to follow this procedure may result in damage to the vehicle. <br /><br />Install NEW "O" rings to the variable camshaft timing oil control unit housing. Lubricate the "O" rings and the bushing. Install the variable camshaft timing oil control unit housing. See Fig. 142. Install the variable camshaft timing oil control unit housing bolts. Tighten to specification. See TORQUE SPECIFICATIONS. <br />Install the variable camshaft timing oil control solenoid. See Fig. 141. Install and tighten the variable camshaft timing oil control solenoid bolt to specification. See TORQUE SPECIFICATIONS. <br />Install the timing chain cover. See TIMING CHAIN COVER (NON-SUPERCHARGED). </span><br /></td></tr></tbody></table>
Husqvarna 345e
I have a model 435 Husky that had the same hard-to-start problem--warranty service replaced the carburetor and it seems to work ok now. The chain that continues to turn can be fixed by turning the idle-speed screw (not the H or L jet screws) CCW a small amount until it can be accelerated then dropped back to idle to quit driving the chain. Hope this helps!
I need to replace the chain sproket on my Hsuqvarna 345e chain sa
It has an out board clutch, please view this it is essentially the same.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed.
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
    Let us know how it worked for you.
IPL and operator's manual download
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
You may find detail B beneficial. HTH
Lou
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
