Question about DeLonghi DE500 Dehumidifier
I have the Delonghi DE500P and the lever that indicates the bucket is full will not stay down and therefore the bucket full light remains on and the fan will not start. when i use my finger to push this lever (that is behind the bucket) down the fan will come on starting the dehumidifier. So i know that the actual appliance works just the lever is causing it not to stay on.
    Brigadier General:
  • 4,736 Answers
Replacing the switch/lever is more trouble and costly than it's worth. That's if you can find the part. I suggest, that you try reinstalling the bucket very carefully, making sure it making contact with the lever in the proper position. Lots of times, the bucket is simply not being inserted properly and it misses the switch. If that doesn't work and you want to repair it yourself. Contact Delonghi Parts Dept 800-865-6330.
Hope this helped you.
Posted on Apr 27, 2011
Anonymous
SOURCE:
Have a dehumidifier, Delonghi DE500P. Unit operates but no water collecting in bucket.Level set to 35%. Can freon be added to recharge?
the short answer is yes , but id caution you on the need too first?
first check the basics:
bucket full lite not on (blinking)
filters clean ?
both fan and compressor inside running (sometimes the fan runs but the compressor does not?) listen carefull for them both?
if your unit needs recharged odds are it's not financial feasible to do so , first you have to fix cause of gas leaking out ? what ever that is ? then you need to add service ports and finally you need a gas charge , this would or could cost hundreds of dollars , a entire new unit is less 200 bucks unless you do all this work your self , but id tend to think if you had all the tools and knowledge to do that youd not of asked here in the first place
Jul 21, 2015 | Dehumidifiers
The full bucket light stays on yet no water is collected
if water full light stays on the compressor wont start and remove water from air , investigate why light stays on ? is bucket really full? is sensor knocked out of its fragile holder ? is bucket all the way inside machine so that sensor is connected ?
Jul 04, 2014 | Kenmore 54501 Dehumidifier
I have a De Longhi de500p. Runs and I can hear the compressor kicking on and run. But I am not getting any water in the tank. Room temp 75 degree and humid meter set at 40 .Please give me some advice
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 31, 2011 | DeLonghi DE500P Dehumidifier
Everything seems to be working although I've set the humidity level at 50 but container still dry and humidity level still remains at 70. I trouble shooted everything per manual by cleaning filter...
heatman101
May 26, 2011 | DeLonghi DE500P Dehumidifier
Dehumidifier isn't not removing humidity. Fan and lights are working, but the water container remains empty. It is not pulling water from air. I think that the heating element may not be working.
heatman101
May 25, 2011 | DeLonghi DE500P Dehumidifier
The bucket full light stays on while it is empty. the humidity control doesn't change. the unit is not going on.
There should be a switch that is activated by a float lever that if tripped will make the bucket full light stay on, and will prevent the unit from going on.
If this light is on when the bucket is empty, maybe try to jiggle the float lever, or investigate why the switch is activated when the bucket is empty.
Good luck on this repair.
Dec 01, 2010 | LG LHD65EBL Dehumidifier
It is flashing E1 and is running with no water in bucket
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 04, 2010 | DeLonghi DE500P Dehumidifier
My DeLonghi dehumidifier model DE500P is tripping the breake
the motor is tight, (can't turn) lubricate the motor bearings with light machine oil. retest. rust causes this. the motor "tries" to turn, more power is needed, still can't turn, power exceeds safe limits: breaker trips.
Apr 25, 2010 | DeLonghi DE500P Dehumidifier
De500p dehumidifier pump stopped working, help!!!
I only got as far as disconnecting the filter between the small water bucket and the pump. I was able to get the pump working again after I cleaned the water bucket and filter by flushing them repeatedly with fresh water. The lines after the pump contained cloudy water, but I figured since the pump was able to push it out past the pump already, it shouldn't cause problems this far down. It saved a lot of time and hard work not having to disconnet the rest of the tubing or take the water bucket off. I also realized if I disconnet the first water collection tubing from just under the front panel and point the open end down, all the water in the bucket flows out. This part is so easy to get to. Just pull out the big collection tank and it's right there on the left toward the back. I can do this every week! Maybe then nothing will sit long enough in the small water bucket to turn into any kind of filter-clogging material.
Jul 31, 2008 | DeLonghi DE500P Dehumidifier
De500p lost owners book
http://www.manualnguide.com/download/manual-guide/
delonghi-de500p-dehumidifier-owners-manual.html
This should solve your problem.
May 05, 2008 | DeLonghi DE500P Dehumidifier
DeLonghi DE500 Dehumidifier Logo
98 people viewed this question
Top DeLonghi Dehumidifiers Experts
nm156
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
