Lay z spa pump has E02 code which is water flow problem,have changed filter.flushed through ,set reset button but fault code still appears.
If this is an outdoor spa near trees, its almost a guarantee that the impeller is blocked with debris (pine needles can cause this in a hurry)
If the impeller is clean of debris and this is still happening, replace you pressure/flow switch.
Could you please tell me where this is. is running from the little clear pipe how do i un block it
Hi, My impeller magnet has rusted and cracked the plastic casing. Why does this cause the E02 error?
Oh, and can anyone point me in the right direction to getting a compatible spare please? Pump Impellers are quite cheap until you search for Lay Z Spa Impellers.
im also looking for an impeller, did you source a compatible one?
We brought a lazy spa last year, its been good up till now. the motor number is 54075, it keeps saying error code E02, i have checked all the pipes and there are no blockages, ive run clean water through the pump and taken it apart, and its all clean. ive donw it 3 times now but it keeps coming up with error E02. can any one help, please
we had same error on our pump exact same model u have here , we found out it was a air lock we put the hose pipe into the pool and blew some water into the pump (we removed the plug inside the pool 1st) made sure all pipes were lined up straight and was stood flat worked fine after pressing the heat button evrything worked as it should
So were you able to figure out how to fix it? and Trish was the pool still full of water and what hose pipe were you referring to to put into the pool?
The mine house is licking water out of it and it is giving the code ever time I put it on the filters part but when I put it on the bubba is don't no more
hi guys have a coleman spa here and love it i have had the error for a long time too i found that if you drill holes in the plastic piece that squirts out the water after going through the pump it helps alot. The filters need cleaned aloooott to keep the error away but you can get away with about a week if you drill holes in output of the thing it lets all the gunk out better.
I have the same problem, i have opened it, checking the pump, putting it again, the tubes looks clean, I plug a tube sending water directly there and it came out perfectly. Indeed, I turn it on while the water was being pumped (not by the pump) and it didn't give me the error, so the sensors are ok, but when i plug it, the pump doesn't even try to work. It did once and since then, error EO2. The weird thing is that when I plug it, it does not even try to suck the water. I checked in internet for another pumps but i can't find much. Any advice? My only solution is to buy an external pump and use it.
I have gone through 3 of these blow up Bestway/Coleman hot tubs, I have decided they are not worth it and now going to spend the money on a more expensive permanent spa.
I have one and I get E02 code I've tried everything. two of the airflows don't seem to be working out of the three of them not sure what is wrong here. I called bestway in AZ they say I need a new pump. at cost of $199. it's a airflow sensor they say.
I had exactly the same issue and found the problem to be the impeller was corroded. It is not available so they want you to buy a new pump which will end up the same. So I retro fitted a $60 pool pump into the plumbing of the Lay-Z spa pump.
I am going to try this with my lay-z spa and was just wondering did you have to cut any of the cords inside the egg? Like maybe the two coming from the old pump? Thanks
I just got a new pump from amazon. I will istall it like the diagram he supplied. I will let you know if anything needs to be done with wires. I would remove power to old pump for sure and remove impeller.
Hi all. I’ve just taken on my mums lay a spa Paris. She’s never had an issue with it and always maintained it well. I set it up two days ago and it was working great til today when we got the E02 code. Probably my fault as husband noticed I didn’t put a filter inside the filter housing. Tried backwashes, everything. Can’t get the code to clear. Any ideas?
Hi all.. we've had the same E02, filter error issue (which seems to be a very common one with the Bestway pump on the Lay z spa).
After only a few uses, the error occurred. Unable to rectify with new filters, we discovered that the 'B' pipe was kinked.. so we contacted bestway who sent out a replacement liner. However.. we've only had it up for a week and already noticed the B pipe is kinked/ squashed and the E02 has come on again!!
This isn't a much discussed problem online, but might explain why many people are also experiencing the E02 code. Not always the need to change the filter.
Bestway recommend using hot water to warm the pipe and re mould it onto shape.
I’m having the same issue. Cleanouts did nothing, flushed pump system with CLR. Can’t locate the impeller, ready to take a sledgehammer to the pump!??
Mark Grays’ solution of giving it a good slap or smack was my solution to clearing the error, jostle it and rock it with moderate force, thank you Mark. I was able to take out some of my frustrations on the pump and solve the E02 issue.
after 4 days of working on my hot tub trying to fix the e 02 Error and taking the steps of Cleaning everything I came across this post and went out there and Jostled it around and it started working I was so mad because it worked.I wasn't Mad that it worked Im mad because I spent 4 days trying to fix it,and all I had to Jostle it. Thank you so much for this post. You have made me a happy woman.
My pump has just done this it's done it a few times. But this time when I put pump back on and take caps off. The water keeps coming out ... I've done a backwash 3 times in last 2 days. Bubbles work great. But filter and heater not doing nothing . And of cause e02 comes up. Please help or does anyone ha e a 54075 model pump for sale .
Just had this with mine. It had just been rein flayed and E02was beeping as nothing had changed and new filter was in I gave the motor housing a gentle shake checking all the pipes were in line. Pressed on and hey presto away it went. Hope yours is as easy to fix
I took the base cover off removed the pump & opened it up, there was loads of hair wrapped around impeller. reassembled all working fine now. As a separate tip a washing machine hose with a male to male adapter the other end in a bucket works in order to test rather than keep connecting then unconnecting to spa
I was having the same issue EO2 for 2 days
What I done was at the base of the pump just give a good slap
Now all is working fine
Problem solved
I've only been in mine tonight for first time and it's already giving me the code
Surely it can't be blocked already ?
Ive had the dreaded e02 code and sorted mine now ! Its says in manual that its a water flow problem. Mine was a blocked return filter. I noticed that what was happening was there was a restriction in water getting back into the tub after being through the pump|heater. With the tub full i unscrewed the top pipe to allow water to escape an an blob of paper slug came out. ( looks like from old filters ). When i get e02 code again i do them same and this resets the code. Hope this helps ! Peter finnigan
How did unscrew the top pipe with it full and get it back together with water rushing out? looking for help.
THIS WAY KEPT ERROR CODE AWAY AND IMPROVED HEATING!
Ive owned my coleman spa for 4 months now. I was getting the error code 1- 3 times a week, consistant with how many times I was in it per week. I found cleaning the filters fixed it until the next time I got in it and E02 code would come up again the next day. I put chlorine tabs in the floater as instructed but water PH level was aways too low (chlorine) and my skin would be itchy dry everytime.
BEST WAY TO KEEP E02 CODE AWAY that I found was to add 1/4 cup liquid chlorine every 3 days which kept PH level at 2-3 with my ph testers AND the E02 error hasnt been back since. Its been over a month now.
I DO NOT RECOMMEND taking pump housing off and messing with the sensor or youll mess it up for good ! !
I had a similar problem where the water pressure had diminished. SOLUTION: with the spa full of water unscrew the top (return) pipe so water spills out then turn the pump on for a few seconds. This dislodges any blockage and is like new again.
Steve, your solution worked perfectly. Took about 30 seconds total and the error code is now gone. Thanks.
Worked me too.....Thanks
Any advice on where to get a compatible pump impeller plz guys. Lay Z Spa ones on ebay seem expensive compared to general pump Impellers.
Active AQUA Replacement Impeller...https://www.amazon.com/dp/B008UFBTES?ref...
Thank you Steve Doran! That solution worked as well. Took a few times (maybe 60 seconds cumulative) but it worked
Hi there having the same issue e02 code, but have noticed the outlet from the filter pipe been quite flat would this be the problem
Which one is the return pipe the one with the filter?
