Question about Sirius Satellite Radio Receiver
I have a 2009 Kia Rio with a factory Sirus Sattlite Radio. I have had the entire radio unit replaced but I still have a problem where I get a message, "Aquiring Signal". This happens even when I am in an open area. At times it cuts in and out alot and at times it works fine. It even works while driving in a short tunnel. I have had Sirius send reset signals but the problem continues. Is it possible the cable is not connected to the antenna good? If so, how do I get the factory mounted antenna loose so I can check the connections?
  • wyncrtr May 25, 2011
    I have thye same problem.
  • Sirius Master
  • 18,139 Answers
There is a separate radio module behind the dash that hooks to the antenna and the radio it is a known issue. Good luck.
Posted on May 05, 2017
    New Friend:
Hi there, you can try to change the radio, if not, you have to see the outside cable signal catcher.
6ya staff
SOURCE:
Edward Lilley
SOURCE: sirus radio
I had to replace my Sportster because it was overheating and caused it to loose signal.
Posted on Jul 13, 2007
Anonymous
SOURCE: Sirius radio repair
chrisckb1973@yahoo.net
Posted on Jan 27, 2008
Anonymous
SOURCE: "no antenna" message
broken connection pin
Posted on Aug 06, 2008
Anonymous
  • 5 Answers
SOURCE: sirius radio signal fades in and out
could it be a bad earth
Posted on Mar 19, 2009
smarthome2
Frank Fulton
  • 1114 Answers
SOURCE: Constantly goes to "linking" whenever I select Sirius. Sirius tells me that means an antenna problem. However, I have tried a new antenna with the same results.
The unit needs to be replaced. solder pins on the PC board of the unit are broken. Clarion has about 100,000 of these units with the same problem. You can find a replacement online for $50 that's been fixed & the problem should not re-occur. Sorry for the bad news. Hope this helps
Posted on Jun 03, 2009
Radio code 1cde is on kia sorento 2009
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
KIA Sorento V6 3 8L 2009 OEM Factory Service repair manual
Jul 17, 2016 | Kia Cars & Trucks
2010 Kia Rio 5 .Radio works but CD player doesn't. It displays Code 5 error.Any idea on how to fix??
Cd Player Error - Kia Forum
www.kia-forums.com/2003-2010-sorento.../59783-cd-player-error.html
May 11, 2010 - 10 posts - ‎5 authors
... Kia Picanto Forum · Kia Rio Forum · Kia Sephia Forum · Kia Sorento ... Have tried a whole range of CDs (copies and originals) but doesn't like ... If the negative battery cable idea doesn't work, try to remove the .... Last edited by pulsar86; 05-13-2010 at 01:42 AM. ... 5 Attachment(s) Kia elan T8D engine vs. Change Rear/Front Speakers 2006 Kia Rio (for ...
Jun 28, 2011
Resetting the radio - Kia Forum
Jun 9, 2011
Kia picanto 2010 cd player removal and mp3 - Kia Forum
Dec 29, 2010
Replaced battery and cd player/radio quit playing ...
May 7, 2008
More results from www.kia-forums.com
Remove Power Supply Fuse For Twenty Seconds if CD ...
Dec 27, 2015 | Kia Cars & Trucks
Kia rio 2009, The car stereo stopped working, red light in top right of deck is permanently on
do you have a code for the radio? contact dealer for one if you do not
May 08, 2014 | 2009 Kia Rio
No power to radio
reset the radio.
May 05, 2013 | 2009 Kia Rio
My radio is only getting am stations. it is a 2002 kia rio. I rarely use the radio. do i need to replace the radio?
Check to make sure the antenna did not unplug from the back of the radio. This can cause you to loose all FM radio signals
Nov 16, 2010 | 2002 Kia Rio
Radio Code
you need a new radio dealers dont always lie and they are FACTORY trained
Jul 22, 2009 | 2003 Kia Rio
Radio does not work after replacing battery
replace radio ,sounds like you flashed the battery the wrong way around and you have killed it
Feb 02, 2009 | 2006 Kia Rio
2003 Kia Rio radio station settings
Go to the radio station that you want, once there, push any of the numbered buttons and hold it there for a couple of seconds. That should set it.
Nov 18, 2008 | 2003 Kia Rio
Sirius Satellite Radio Receiver Logo
363 people viewed this question
Top Sirius Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Anthony Ward
Anthony Ward
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
