The float inside the carb is probably stuck in the open position...you may need to remove the carb and have an overhaul kit installed in it....if you stored the unit without draining the fuel from the tank AND the carb, then the fuel probably went bad and has become "varnished". This fuel degradation can cause the float to stick and clog up the main and idle jets
