Roper RAS8445KQ Top Load Washer Logo
Posted on Apr 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My washing machine want drain out the water but it will spin what do you think the problem is is there a relay for that.
Anonymous
Level 3:
Master:
  • Master 414 Answers
  • Posted on Apr 26, 2011
Anonymous
Master
Level 3:
Master:
Answers
414
Questions
0
Helped
99393
Points
1225
The pump is most likely clogged. this is a direct drive pump, which is connected to the
motor, Usually it is a small sock in most cases. You will need to drain as much water
as you can (A shop vac is ideal for this) and **** the water from the drain hose as
well before detaching the hose clamp from the tank to the pump. Use a kitty pan to
catch the remaining water. The pump is accessed by having someone tilt the
unit to access the underneath. Pinch the spring clamps and move them back to remove
hoses. Unplug the unit before servicing. Hope this helps.
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
2answers
3helpful
The washer isn't draining and spinning. Washer has message coming up- OE and it stops working. We were thinking it was the water pump? Please help.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
2answers
My cabrio wtw6700tw1 does no rinse so the water not drain out of the basin
heatman101
My GE spacemaker top loader will not drain, makes buzzing noise
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
1helpful
Standing water in the washer hours after wash cycle completes
YES..I think drain hose @ sink too low Waste water from sink entering machine...Raise pipe....tie up ....
4helpful
2answers
I have a Hoover 750L washing machine and it is not spinning now in the washing circle so the clothes are soaky wet. How can I fix this problem
is this not spinning due to not pumping out water/..if so clean drain pump/check filter.this should fix
Washes but does not rinse or spin . I think the pump is not working, it is not draining the water out of the washer which is causing the rinse or the spin to work would it be a switch or the pump
After wash the water drains out of machine automatically but its not drainout means the drain motor is not working properly or proper power supply is not given to the drain motor
2answers
Washing machine will fill with water, but won't spin.
hi there.
If the washer won't drain or spin there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.16 Mar 2014
SOLVED: Why won't my washer spin or drain? - Kenmore 110 Series ...
or go to this link for more help.
Washing machine will fill with water but won spin Google Search
1helpful
Whirlpool Ultima Wash II Intermittent Rinse/Spin
Hi, the water not drain , the drain pump was stuck , causes are the small linen and other foriegn materials are bind the pump infeller , pump connot completely turn . so drain stuck need to clean , also the drain hose have sedimentation of soap and dust.
Top Roper Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
