Hi
There are two types of water filter fitted to this model they are both located in the top right hand corner of the refrigerator section.
1. The standard water filter looks like an upturned bowl, to change this you need to unplug and switch off the unit, turn off the water supply and unscrew the filter around 1/4 turn anticlockwise.
Replace the filter and tighten the bowl checking that the O rings are in place. You may make a bit of a mess with water dripping out as you remove the filter bowl. These can be quite stubborn if they have not been changed before.
2.Pure source filter is on the face of the unit next to the thermostat, again shut down the unit and turn off the water before removing the filter, there is a small button lower right on the face, when you press this the filter should pop out, again spilling some water.
It is vital that you prime the system properly before using the water or ice this means running at least 2 gallons of water out of the water valve on the front to make sure that all the air is out and that pure water is in the machine.
You manual is available at this link
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/241856000en.pdf
Hope this helps
Gordon
