the waste toner container is located on right side way of copier behind plastic cover in left angle, near the paper path door.
Hope that helps!
You will also have to reset counter in service mode. First reset the copier by getting into service mode. Additional Function key, then the 2 & 8 pressed at the same time, then Additional Function key again. Press COPIER on display, then Counter ( across the top ), then MISC, and then the clear key.
