Consew 255RB-3 Mechanical Sewing Machine Logo
Posted on Apr 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After replacing the bobbin the sewing hook/bobbin doesnt turn anymore. It will spin if you turn the wheel backwards but it wont do anything when turned forward.
Anonymous
Level 2:
Scholar:
  • Expert 111 Answers
  • Posted on Apr 27, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
111
Questions
Helped
31879
Points
167
Did the machine get jammed? Maybe the timing belt clutch came disconnected. Look on the bottom of the machine while turning the hand wheel and see if the lower horizontal shaft is turning at the left end. If not, you have to regage the clutch. Let me know if this the case.
1helpful
My bother power sewing machine has lock up the wheel will not turn
Try to turn the hand wheel backwards possible thread stuck on the needle hook by the bobbin. Take the bobbin out and remove the face plate and clean machine.
1helpful
4answers
Hand wheel wont turn to raise needle.
If handwheel does not turn, you may have thread jammed in the hook. First try to force the handwheel BACKWARDS to try to force thread back out of hook. If handwheel turns, look around hook area and you will probably see a small piece of thread. Remove it with tweezers. To help eliminate this from happening, be sure to hold the needle thread when starting off.
The bobbin won't spin in hook
Bobbin won't spin in hook? .. you may have something blocking the thread 'path'...or sensors? Try threading manually, right through with some unwaxed floss... while the machine is turned off.. or better still.. as you do each thread 'tension' area... check with a flashlight to see there isn't anything lodged (old threads caught anywhere...) when was the last time you had your machine cleaned?
Needle wont go into bobbin
Never EVER turn your wheel backwards... that causes it to go out of time. Take your machine in for Timing.
My singer 9410 machine isn't working the wheel doesnt work anymore
it's possible that either a part is worn, broken, or damaged only a sewing machine repair shop can tell what's wrong
1helpful
Probably something jammed in or near the bobbin case or hook area.
Sewing machine jammed wheel will not turn
Thread is caught in the hook...Remove the upper thread and bobbin case...turn the hand wheel backwards and forwards by hand and remove the thread remands. Good Luck
Sewing machine arm wont come down
You need to remove bobbin case and turn hand wheel backwards and forwards by hand till needle comes up and remove race hook cover and hook....remove all thread remands.. and reassemble.
Top Consew Sewing Machines Experts
Paul Bade
NOEL
NOEL
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
