SOURCE: Washing Machine door latch replacement
Go to searspartsdirect.com and type in your model number. The door latch assembly can be found under the "Door and Latch Parts" heading as item number 7 (part #8181700). If you need instructions on how to replace, just follow this link:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
If you do not wish to purchase parts online, use the part number provided and go to your nearest appliance parts retailer. I hope this helps you.
SOURCE: Mid-cycle my washing machine stopped working.
Could be one of three issues, timer, capacitor, or the most like canidate the motor assm. Usually 90% of the time, its that motor. Those motors are pretty expensive (part number 389248) and you need to replace motor coupler (part number 285753A) when you change it.
SOURCE: Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
SOURCE: Washing machine will not complete spin cycle
OK, what you are experiencing is a timer mechanism fault. the timer motor is malfunctioning. anytime you have to manually advance the timer knob, this will signal a fault within the control mech. this is easily fixed by, replacing the timer control module. i will place a link to the actual part needed to fix this issue. you can also purchase this timer on line at this site if you wish.
CLICK HERE
