Many of these devices use a code that changes each time the door is opened and closed. This feature is used to keep potential bad people from learning your operational code and entering your garage. You may have a communication problem whereby the Garage Opener needs to be reset. You may try to change the settings. If you have dip switches on the main unit in the garage, change the dip switches to another setting and write down the numbers in the order that you have the set them, Then go to the remotes, hand held and hardware placed on the outside door, and change the settings on these devices to MATCH up with the inside unit. This is a good time to REPLACE the batteries also.
SOURCE: garage door remote won't open the garage door
The little button with a padlock on the wall control is a "vacation" lockout feature that disables the remotes. There should be a small LED on the wall control that is always on steady. When the padlock button is pressed and released the LED should be constantly blinking (indicating the vacation lockout mode is active) and your remotes should be disabled. The wall control will still operate the door. Pushing the padlock button again should make the LED stop blinking and restore the door to normal operation.
SOURCE: flashing green light on Sears garage door wall opener HBW0777 1/2
Same problem - The flashing wall button indicates the remotes are locked out. I fixed mine by pushing the green button on the back of the opener. I did nothing else , just left the LED time out.
SOURCE: Sear garage door wall mount contol light keeps blinking
One of the buttons has a lock icon. Hold that button in for 3 seconds.
SOURCE: Problem with Sears Garage Door Opener
The motors is cought on something check the motor if it moves inches it will move a yard the question is the motor is it getting power? if so is it stuck on its own drive chain? Check these things you be glad you did.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
