You must reattach blades with the clipper running in order for them to seat correctly
Hair Clipper Blade Replacement Tutorial
SOURCE: oster clippers
Found another web site where some one had posted the information I needed. I just used Google search and found the information.
SOURCE: have pro clippers do not have instructions for changing blades
Schematics are located at this link. Hope this helps.
http://www.clipperrepair.com/parts.htm?brand=8
SOURCE: NEED PARTS FOR OLDER OSTER CLIPPERS
I gave it a shot and it worked!!!....
No need to bother with the universal guards. They looked bulky for the task, and after careful (visible scrutiny) decided to gamble on the "fast feed clipper" guides. Check them out here:
http://www.cache-beauty.com/oster0541.html
There are surely other people who sell them - you might shop around, but I bought from these guys. Warning, the shipping price is kinda steep. But like I said in my last post, I've tried other clippers and these are just the best. It was worth it to me.
Anyway, I am now confirming that these guards fit this old clipper brand of ours. Perfectly!
SOURCE: blade change problem & no info in enclosed instructions
Hi A5 blades are not made to be unscrewed. They are snap on blades. You can call 800-830-3678 which is Oster Direct consumer service. They will walk you though the process or you can send them back to Oster and they will put them back together and realign them for you. Hope that helps.
SOURCE: CHANGING BLADES
There is a small gun-metal colored bar (dark gray or black) at the very rear, just below the back of the blade. It pushes inward, in the direction of the blade. Push it firmly in and pull up on the teeth of the blade. It should pop upward. You can then remove the blade from the tongue that it sits upon. When you want to put it back, slide the blade back on the tongue, then, WITH THE MOTOR TURNED ON, push the blade down to its seated position. It will click into place.
Hope this helps you.
